Results 1 to 15 of 15
Thread: Valve cover removal
    May 2004
    A COOL place!
    Valve cover removal
    I am trying to take mine off and have run into problems, they are tight on the right it is the AC box on the left it is the brake booster! How the heck do you get them out?
    # 2352 Lidio Built my Hot Rod... 2011 S55-001
    Aug 2004
    Maryland
    Search around. I did a very detailed write up with pics on the subject. Have fun!
    11.98 @ 115 mph
    Longwood, FL
    When you find Defyant's post, please put the link in here. I need to do it again, and don't want to spend all day on it next time.
    Basically, you have to remove the passenger side motor mount nut and jack up the motor 1-2" to get clearance of the AC box (I also loosened, but did not remove, the same nut on the driver's side). You'll also need to take off the heater hose from the side tube, disconnect the fuel line, and disconnect the plastic emissions tube thingy. In the process of removing the valve cover, you will stretch the valve cover gasket because it is cemented to the head with silicone sealant at the point where the timing cover joins up to the block. I was able to reuse mine by letting it shrink in the afternoon sun for about 30 minutes, and then finishing up the shrinking process with a propane torch. I do NOT recommend this methodology. Next time I am just gonna spring $50 for the felpro gasket and tube grommet set.
    2003 300B
    VIN: 677166, #6738 of 7839
    built: 2/13/03
    wrty start: 5/28/03
    84,197 on 02/21/08
    95,776 on 02/21/09
    109,301 on 02/21/10
    121,447 on 02/21/11
    125,925 on 02/26/12
    130,375 on 01/01/13
    134,831 on 2/4/14
    149,441 on 2/24/18
    Dark Blue Pearl, #128 of 327
    wow i dodnt realize it was such a pain in the ass
    Jan 2006
    Central Ohio
    Quote Originally Posted by DEFYANT View Post
    Is THIS it?
    KillJoy
    You dont need to jack up the engine by the way.
    You do need to remove the wiper cowl and assembly.
    I had to do both.
    I had to do both.
    Inexperience will cause that.
    Longwood, FL
    me still a noob. next time I'll re-read the defyant thread before I start - yes killjoy, that's got to be the right one. funny how I understand more of its true meaning this time around - experience certainly is the best teacher.
    2003 300B
    built: 2/13/03
    wrty start: 5/28/03
    84,197 on 02/21/08
    95,776 on 02/21/09
    109,301 on 02/21/10
    121,447 on 02/21/11
    125,925 on 02/26/12
    130,375 on 01/01/13
    134,831 on 2/4/14
    149,441 on 2/24/18
    Oct 2007
    CA
    where caI get thoose blue covers???
    Aug 2003
    Central Iowa
    Inexperience here, too. We had all the cowl/wiper parts removed nad tried everything we could to get it off without doing the motor mount. Now, we did not remove the upper intake or any EGR stuff when we did mine. Undid the motor mount, tilted the motor, and wa-la, it came off...
    Eric
    2004 Silver Birch Marauder - Sold 04/17/09:
    - #2703 of 3213 '04 Marauders
    - #852 of 987 Silver Birch Marauders
    - Born On Date: 04/23/04
    - Warranty Start Date: 08/11/04
    - MINE as of: 09/09/05
    2003 CVPI - Daily Driver
    - Purchased 05/29/07
    Quote Originally Posted by Eric91Z View Post
    A good yank (without fear) will get it off.
    Grind down that casting before reassembly and it goes right back on.
    May 2004
    A COOL place!
    Well since I found a oil leak on one cover it goes to the dealer tomorrow,my warrante will cover it all. So they will get powder coated and put back on.sweet!
    May 2004
    A COOL place!
    Dealer Pd me OFF they assembled everything before I could get there.So someone had a set of covers floating around on this site anyone know where they went?
    Actually I didn't want to mess up the powder coating..........
  1. 360HP valve cover decal.
    By FW_Linc/Merc in forum The Classic Lounge
    Last Post: 09-08-2007, 10:58 AM
  2. Valve Cover Color?
    Last Post: 05-24-2005, 05:09 PM
  3. Valve cover paint
    By Mike Poore in forum Community Discussion
    Last Post: 12-19-2004, 11:58 PM
  4. Question about tranny shift pressures
    By Fourth Horseman in forum Reinhart Automotive
    Last Post: 08-06-2004, 09:50 PM
  5. Replacing the valve cover gaskets.
    By Long Live #3 in forum The Lounge
    Last Post: 03-18-2004, 08:18 PM
