Results 1 to 6 of 6
Thread: Traction control bypass (Lock out)
    In Harms Way.
    Made couple of passes at the local track last night and upon leaving realized that I forgot to turn off the traction control on each pass.
    Has anyone connected up a system where as the traction contol is turned off when the O.D. is turned off with the button on the shifter.
    That way both things are done at once, easier to remember (at least by me).
    4 doors - no waiting.
    2004 Mercury Marauder, BLACK w/Charcoal.
    Built 09/04/03
    #261 of 1236 Blacks, 3213 total for 2004
    (Thanks RoyLPita)
    Purchased 10/23/2003
    Adopted 04/25/2004
    Hot seats, 6 disc, trunk org, spoiler, avic f90bt & xm, ts-d802 speaks, bumper inserts, pedal and sill covers, 23% tint, 8000k hi/lo hid's & fogs, pro-guard, c.a.i., Xcal2, u.d. pulleys, emp pump, 180 t-stat, autolite 103 plugs, cop connects, coil covers, converter, aluminum pan & cooler, intake spacer, 4.10's, girdle, sway bars, control arms, head cooling kit, shorty headers w/ x pipe, dead pedal, budget big brakes.
    "Come with me if you want to live
    Not possible.
    Use the button provided.
    2017 Niro
    In Harms Way.
    Quote Originally Posted by CRUZTAKER View Post
    Not possible.
    Thanks Barry,
    if I could only remeber.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    When I first started racing the MM I got some blue painters tape and wrote the word OFF on the tape and stuck it right about the traction control. Now I've just got into the habit so much of turning it off when I was running 235/50 all around that right after I start the car up I turn T/C and O/D off right away.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    In Harms Way.
    Thanks for the tip.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    Not a problem, it's a simple thing to do and works. Or make yourself a small checklist and tape it to the steering wheel. I've seen a lot of pro racers do that when they have a million and one switches.
    300B
    Exhaust by Greg
  1. Z&M Control Arm Install Detail.....DUW!!!
    By MM2004 in forum Steering, Suspension & Brakes
    Last Post: 08-13-2007, 10:53 AM
  2. Traction Control ... Learn to drive, eh?
    By SergntMac in forum Steering, Suspension & Brakes
    Last Post: 01-26-2006, 11:25 PM
  3. Panel w/o traction control vs. panel with Traction Control
    By ultravorx in forum Community Discussion
    Last Post: 02-03-2004, 01:59 PM
  4. Is traction control available as an add-on
    By mtnh in forum Community Discussion
    Last Post: 08-26-2002, 07:28 AM
