Where can I find front coilover installation instructions & bolt torque ratings ?
Did you try the search box?
Not to be a smart ass but yes for the last hour. Under shop talk "swap spring any tips" by J Man post #12 on 5/6/06 is the most informative. I need torque ratings for the nuts on coil overshock hat assembly, ball joint nut, brake calliper mount bolts.
Today I will be installing the Naake front coil overs S/A with a spring rate of 450lbs.providing sizing is correct along with the Addco front monster sway bar. If all goes smooth I will also paint the brake calipers for a little bling. I will take photos and post soon.
If anyone has torque specs for front brake caliper mount bolts, ball joint nut, top hat nuts & piston rod nut that would be helpful.
You really need to invest in a shop manual...
Brakes
- Front caliper bolt - 32
- Front brake hose bolt - 41
- Front caliper anchor plate bolt - 118
- Bleeder screw - 15
Suspension
- Shock to lower arm nut & flag bolt - 166
- Shock top stud nut - 37
- Shock to crossmember upper nuts - 22
- Stabilizer bar bracket to frame nuts - 46
- Stabilizer bar linknuts - 46
- Upper ball joint to wheel knuckle nuts - 111
- Lower ball joint to wheel knuckle nuts - 111
All are lb-ft.
I can give them to you in Nm if you want.
Fastblackmerc - Thank you for the torque specs.
