I stumbled across this and I believe it can be a possible solution for those of us wishing to push the limits of ours cars....
This could probably easily be adapted to solve the problem we have when upgrading our fuel systems for major power. The problem I have and many others have came across when upgrading their entire fuel system from fuel pump(s) to injector has been the small line size of the fuel tank hat line. No matter how large a fuel line we run, fuel pump(s) we use, size fuel rail we install, or upgrade our injectors we still have a small fuel line from the fuel pump(s) to the where we connect the fuel line that runs the length of the car. This can solve that issuse and greatly reduce the fuel pressure drop we get there. It would allow use to greatly improve the ease of fuel deliver and the power output/performance of our cars.
"Better Explaination":
The major weakness of the stock fuel assembly is the size of the feed at the top of the assembly. No matter how good of a pump you put into the assembly they're trying to push fuel through the small straw sized opening. In addition to that the stock fuel lines, connection at the filter and connection at the fuel rail are all bottlenecks which keep the efficiency of the system very low.
Fore Precision: Triple Pump Fuel Hat
http://www.lethalperformance.com/pag...-fuel-hat.html
One of the main features of the Fore Precision Triple Pump hat is that it's the only system on the market which allows for 3 Ford GT Supercar pumps to be used in tank. You actually have the ability to run 1,2 or 3 pumps at a time so depending on your specific needs you can custom tailor your setup with this piece. In order to run the 3rd pump you'll need to use the Zone 5 Performance MDM Mega Driver. The Mega Driver is an all in 1 driver box similar to an FPDM but allows you to run anywhere from 1-3 pumps at the same time. The MDM Mega Drive provides the pumps with the proper amount of voltage to handle the power that the pumps draw.
Triple Pump Hat Features:
-(3) -6an Outlets for Maximum Flow -Accommodates Dual or Triple Ford GT fuel pumps as well as wiring for Single, Dual and Triple input from the Zone 5 Performance MDM Module.
-Direct replacement and bolts right in using an OEM gasket for a perfect seal as well as using the OEM fuel sending unit in the same stock location.
-Eliminates the PPRV and offers a direct in-tank hose routing to both fuel pumps for optimum fuel delivery.
-Three pairs of gas blocked 12 gauge conductors using 12ga Mil Spec fuel resistant wires for fuel pump wiring to the Zone 5 Performance MDM . This allows your Ford GT pumps to operate without losses from undersized OEM wires and will help in dropping duty cycle. Wiring for the ground and fuel level sender also included.
-No welding or caulk used in assembly or manufacturing. Full billet components use o-rings, OEM seals, and gas blocked through conductors.
-All assemblies are pressure tested prior to shipping.
The top hat includes:
CNC Machined & Anodized Top Hat Assembly
All Gas Blocked wiring for the Pumps, Ground and Level Sender including the proper spade connectors to connect the wires to each fuel pump
Pre-cut and installed Gates 30R10 Submersible Fuel Hose for each pump
All XRP an Fittings
New Bolts for mounting the assembly to the fuel tank
Note: The Top hat assembly when purchased alone does not include: Fuel Pumps, OEM Fuel Level Sender or OEM Gasket. These are items which can be reused from your stock hat assembly or purchased seperately.
In order to run the Triple Pump setup the triple pump option must be purchased. The triple pump upgrade option includes CNC machined 3-1 y-block, third pump retaining o-rings, in tank fuel line, hose clamps, third AN-6 fitting, and third fuel pump prefilter.
The Fore Precision Works top hat can be purchased by itself or as a fully assembled fuel system along with pumps, lines, rails, and the Zone 5 Performance MDM Module.
NOTE: You don't have to run all 3 pumps with this hat for it to function properly. The 3 pump hat can run 1, 2 or 3 pumps. So for those that want to upgrade their fuel system but not add the 3rd pump you can run dual pumps in the hat with a Lethal Performance Dual FPDM kit without having to run the MDM. So as you can see the Fore Triple Pump hat for the 99-04 Cobra/Mach-1/GT can be utilized in many other ways then just a triple pump system. It's versatile, easy to install and best of all performs!
The main site to browse through on your own:
http://www.lethalperformance.com/for...g23502mikcook5
