Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
Thread: Low idle at stop light.
    Jul 2008
    Sunrise Florida
    when the a/c is on, or the car is in park or N, its right were it should
    be but if the a/c is off and iam at a stop light or a, parking,
    lot it feels a lil low, it only has 45,000 mabey I should change
    the spark plugs or clean out trottle body, I dont think
    the injectors are dirty always used 93 octain and changed oil,
    with syntectic valoline, air filter is clean too, its realy get'ing
    me angry I dont undertand please help... SOON!
    Just a tought mabey its the battery? it is the org from what I seen?.
    Never Drive Faster Then Ur,
    Guardian Angel Can Fly...
    Hawaiian Islands
    What type of air filter do you have?
    If it's the "oiled" type (K&N), you need to clean your MAF...
    ALOHA
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Jul 2008
    Sunrise Florida
    Quote Originally Posted by Local Boy View Post
    ALOHA
    Did that last week cleaned the heck out of it,
    mabey i oiled it a lil heavan'ly but it was doin this befor
    but who know's mabey it just wants the reg filter I dunno.
    Hawaiian Islands
    If you are certain the Maf is free of oil residue...
    I would look for a bad ground somewhere...
    Good Luck...
    ALOHA
    *10 lbs. Boost
    *P1SC1 ProCharger
    Jul 2008
    Sunrise Florida
    Good Luck...
    ALOHA
    dont think it could be the trottle body?
    Hawaiian Islands
    Nah...
    If it was the TB...would be all the time...
    ALOHA
    *10 lbs. Boost
    *P1SC1 ProCharger
    Jul 2008
    Sunrise Florida
    ground
    crap I gota take my family some were, um does the ground
    your talking about have something to do with the batt?
    Hawaiian Islands
    Bad grounds are a B*#tch to find...
    Try checking across your Bat. terminals, with a volt meter, to see if you are getting between 12-13 volts...This will rule out a bad Bat.
    Then do the same with the motor running...you should see @ 14 volts, with the Alt. charging...What does your volt gauge (in car) read, when car is on?
    ALOHA
    IF all check out "OK"...consider below...
    When was the last time you cleaned/changed out the plugs? Maybe time for Seafoam treatment!!!
    *10 lbs. Boost
    *P1SC1 ProCharger
    Feb 2008
    Boston
    Randy I thought our volt gauges were phony??
    2003 300A
    #4916 of 7839
    N/A Bolt on's
    4:10 Gear's
    Steeda Underdrive Pulleys
    Stewart EMP Waterpump
    Sparta Control Arms
    Zack Tune
    TCE SS brakelines
    [LEFT]SS Insert's[/LEFT
    Hawaiian Islands
    Nah...Not phoney...Just inaccurate...
    I believe they read a little low...
    ALOHA
    *10 lbs. Boost
    *P1SC1 ProCharger
    Jul 2008
    Sunrise Florida
    pully system
    mabey it has something to do with the pully system,
    just a tought could be a altnator starting to go bad
    I dunno its buging the crap out me I need to find out
    this problem by this moreing its a must, mabey evan a
    tighter belt, oh and I never changed those plugs ther
    factory plugs I think?.
    if im not mistaken I think the gauge in the car read, 12 - 14?
    it floats when i rev?
    Rockford
    A/C & defrost mode kicks the throttle up to keep the motor from stalling under the additional load of the compressor.
    Might check the throttle position sensor it's on/near the throttle body.
    Maybe someone can give the volts to see if it is within specs.
    Do you have spell ^?
    Jul 2008
    Sunrise Florida
    Quote Originally Posted by Bradley G View Post
    what do you mean by spell?, and do you have any pics
    of the sensor?.
    thanks
    Rockford
    look and ye shall find.
    Your posts are getting better, but take a moment to preview them.
    Your spelling and grammar if the word is underlined it is not spelled correctly.
    click on the underlined word to see variations of the word.
    Apr 2005
    The Pitt, PA
    This is a classic.
    Clean everything wash and oil your filter - put it all back together. runs like butta for a day then starts dozing off.
    The fresh filter oil got on your clean MAF. Clean it again.
    2013 Ford Taurus SHO
    #1649
    boi
  1. Practical Invisibility.
    By Aren Jay in forum The Lounge
    Last Post: 08-12-2008, 08:57 PM
  2. Rough at idle
    By mtenderenda in forum Shop Talk
    Last Post: 07-16-2008, 05:05 PM
  3. Clev. Meet Beer/pop List
    By CRUZTAKER in forum Events
    Last Post: 06-08-2006, 08:02 AM
  4. Illegal Hid Head Light Conversions
    Last Post: 05-23-2006, 08:47 PM
  5. Red Light Cameras Increase Accidents
    By dwasson in forum The Lounge
    Last Post: 04-04-2006, 04:03 AM
