Results 1 to 15 of 17
Thread: Seat Belt Chime
    Boston
    Seat Belt Chime
    Hello I was wondering if anyone knows how to shut up the seat belt chime.
    I put my seatbelt on and it still goes off! I think it has something to do with the Airbag light being on as well - or its two different problems. Either way the dealer wants 500 bucks.
    I hope its cheaper to locate the speak and
    any help would be appericated!
    -Eric
    2004 Marauder - Best Dyno: 277whp 295wtq
    Mods: Kooks, DEZ tune
    In the manual, it tells you how to disable the chime. But as you mentioned, it could be related to the airbag light?
    Taxachusetts
    Unplug it under the seat
    Marauderless....
    Feb 2008
    Boston
    Eric I'd get that airbag light fixed as soon as possible, a co-worker of mine had an airbag light on in his work truck (ford ranger) for a while and last week he got in the truck, started it, put it in drive and turned the wheel to pull away and BOOM!! It blew up right in his face! I was standing right there, it was the funniest thing I ever saw.
    2003 300A
    #4916 of 7839
    N/A Bolt on's
    4:10 Gear's
    Steeda Underdrive Pulleys
    Stewart EMP Waterpump
    Sparta Control Arms
    Zack Tune
    TCE SS brakelines
    [LEFT]SS Insert's[/LEFT
    Boston
    Yea...I just dont trust dealerships and I dont like shelling out 500 bucks for them to tell me its a .2cent plug. Plus they have to take my D3 out....
    -Eric
    Boston
    Where is the plug TJ? Do elaborate obi wan
    -Eric
    Apr 2005
    The Pitt, PA
    Dude, disable it via the manual instructions. Don't mess with airbags.
    http://www.magindat.net/ssm/info/MMownersmanual.pdf
    2013 Ford Taurus SHO
    #1649
    boi
    Nov 2007
    Carrsville, VA
    If you unplug the seatbelt connector, it will also cut on the airbag light. The seatbelt buckle switch is used to for the strategy on airbag deployment. If you disable the lamp via the procedure in the owners manual, you won't have a problem. If you have an airbag light on, you need to diagnose it before continuing. Look under both seats near the buckle to see if someone else has disconnected the connector at the buckle to attempt to shut up the warning lamp. If the connector is disconnected, buckling your seatbelt will not do anything since the RCM cannot see the belt is in the buckle.
    98 Marauder-wannabe--Forged rotating assembly, aluminum block, PI heads, Allen Supercharger.
    12.87 @ 104.8 355rwhp/430rwtq
    Boston
    How can I look under the seat? I tried and its hella hard to figure anything out under there! I will look when i get home it is SO weird that its asking for the seatbelt to buckle and i do it with both and nothing
    -Eric
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by Eric-Blk2004 View Post
    Flashlight + mirror on a stick (from any decent FLAPS)
    #1649
    boi
    Sep 2006
    Cape Coral, Fl.
    The fact that the chime stays on indicates that you have a fault in the system. You mention you have a D3. Did this problem occur after installation? Did you ask the dealer what they were repairing or replacing? The seatbelt and airbags function together as a system, one that I would prefer working in case of an accident. If you don't know what you are doing with it you can get hurt. As a technician I know most aftermarket shops do no have the equipment to diag airbags. Ask the dealership what they were going to do and throw that out here for disscussion rather than you were getting ripped off for 500.00 bucks.
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by finster101 View Post
    Let's not go here, k?
    The radio in this car has absolutely 100% NOTHING to do whatsoever with the SRS system PERIOD!!!
    That's a GM thing!!!!
    I think my boy was simply making a sarcastic remark about the incompetence and excuse making of some dealers.... and he'd be right.
    #1649
    boi
    Sep 2006
    Cape Coral, Fl.
    Don't get me wrong I was not flaming the install. There is a connector for the SIR at the base of the column where the clockspring comes down containing steering wheel controls and connections for the airbag. My main point is you can not just guess at this system. I am thinking it could be something as simple as the buckle needs replaced. If there is a code it should flash with the air bag light. I'm not trying to start crap Rich, but I don't want people to take these things for granted. They will hurt you.
    Boston
    I posted a few threads before on the matter. It was after the installation I asked the installer he said he tapped into the sterring wheel controls behind the unit and not in the column. He never took the column cover off just worked in the dash.
    The code it is flashing is 53. The dealer said it would be 500 bucks to follow the flow chart to figure out what exactly is the problem and that they would have to remove the screen to get full access. My installer is booked solid and removing the screen is costly in of itself.
    Worst case I will just save 50 bucks a month and wait till next year and address it when it comes time to pass inspection. I dont like throwing money at problems but with a code 53 the tech said it could be anything electrical. I think its total crap - he said the flow chart is 3 to 5 hours and he charges 110 an hour
    -Eric
    Apr 2005
    The Pitt, PA
    My reason for posting, exactly!!! I couldn't agree more.
    Of specific note - and I say it all the time to keep people out of that column/clock-spring area - the VSS signal is IN THE RADIO HARNESS!!!!
    #1649
    boi
  1. 4-point, 5-point seat belt harness?
    By jdando in forum Shop Talk
    Last Post: 07-07-2007, 11:03 PM
  2. Seat Belt Nagger
    By celtictexan in forum Shop Talk
    Last Post: 01-19-2007, 04:26 PM
  3. What can we do about annoying seat belt beep?
    By emcars in forum Shop Talk
    Last Post: 05-12-2004, 04:14 AM
  4. Any suggestions: New 6.5 in sub causes middle seat belt to vibrate
    By adrian36 in forum Community Discussion
    Last Post: 12-15-2003, 08:32 AM
  5. seat belt alarm
    By kashvili in forum Community Discussion
    Last Post: 01-12-2003, 08:24 AM
