Will a mustang upper and lowers fit on the marauder. if so what years? looking between steeda and upr products?
SEQ #3042 of 3213.
has anyone tried this?
SEQ #3042 of 3213.
I believe they are different
pretty sure they are different yes
different, the closest you can get are town car CA's I think Joe Walsh tried that but im not sure. Reinhart sells bad ass CA's , they make the car plant and handle much better.
Metco's
Dennis sells some other brand that I don't recall
Zack may have some of his and Mac's design.
Mustangs won't work.
04 Crown Victoria Sport
1995 F150 4x2 4.9 5spd
They are very different and will not fit.
445rwhp/408rwtq - 12.6/110mph
DR Vortech NOIC #5
Sold
Zack's ftw, don't have to grease the bushings every 6 months like the Metcos. But either one will do.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
Someone did use a set of Lincoln Limo control arms and they looked pretty good.(quote)
I have the billet aluminum Limo uppers and the oem boxed lowers.
I checked them not so long ago, they are holding up nice.
