Results 1 to 15 of 18
Thread: FACTORY: Two inch or Two and a Quarter inch
    Apr 2007
    Southeastern, PA
    Question FACTORY: Two inch or Two and a Quarter inch
    I want to replace my stock mufflers on my '04 Marauder with Flowmasters but I am getting conflicting reports on the pipe diameter. A few PM's on this list produced replies of 2" and 2 1/4", about 50/50.
    Flowmaster says it could be 2" or 2 1/4", cut the pipe and find out?
    Walker says it is 2"
    Magnaflow says it is 2 1/4"
    Flowtech says it is 2"
    Borla says it is 2 1/4"
    I prefer to order the correct mufflers without cutting the pipe and then ordering the correct mufflers. I know the inlet is offset and the outlet is center.
    Thanks
    Aug 2003
    Graniteville S.C.
    2.25 AND LATER WHEN YOU GO BIGGER YOU WILL BE THAT MUCH AHEAD. Sorry for yelling stupid computer...
    Apr 2007
    Southeastern, PA
    Quote Originally Posted by ROB502 View Post
    I already know the bigger part therory, but if I purchase the 2.25" and the factory pipe is 2", I will have a 1/4" gap. I would like to install the correct size. I am looking for the actual diameter of the factory pipes so I can install the correct size.
    Aug 2003
    Graniteville S.C.
    The muffler shop will weld in the gap no problem. If you want no gap then go 2" and they can expand the pipe and just clamp it.
    Lehigh Valley, PA
    the H pipe is 2", the rest is 2.25"
    2063/3214
    5377/7838
    Jan 2006
    Central Ohio
    Go out and measure for yourself, so there is NO ONE else to blame?
    KillJoy
    Lehigh Valley, PA
    Quote Originally Posted by KillJoy View Post
    KillJoy
    that works as well
    But if you pull the H pipe off be prepared to have to replace the gaskets, or it will leak.
    2063/3214
    5377/7838
    2 1/4" tailpipes.
    Apr 2007
    Southeastern, PA
    Thanks...exactly what I was looking for! I'll probably go with 2.25" and have the ends of the H pipe expanded
    Aug 2006
    Calgary,AB Canada
    so does this mean you get a 2" muffler and expand the muffler or the pipe on the car?
    4;10's,JLT RAI,and Lidio's sct live wire,new air freshner,.......and now #153 Trilogy..377 hp and 400 lbs
    Quote Originally Posted by n3fvg View Post
    Only the crossover is 2", the thru pipes are 2.25"
    Apr 2007
    Southeastern, PA
    That explains it better! I thought the inlet pipes were 2" and the tailpipes were 2.25". I won't need to have my exhaust guy do any expanding..I'll just get 2.25" inlet/outlet mufflers.
    Thanks again!
    Jan 2006
    Owensboro, Ky
    If you read this after drinking you will have even a bigger headache.
    If I gave a crap about gas mileage I would own a bicycle. With my luck I may have to go bike shopping tomorrow.
    Black '03 300a SOLD. 1993 Crown Victoria LX. 5.4L Supercharged/6speed. SOLD. New ride:
    Apr 2007
    Southeastern, PA
    Quote Originally Posted by Georges93LX View Post
    True...very true!
    Nov 2005
    USA
    Stock tailpipes are 2¼", and the midpipes are 2" (including the inlet/outlet of the stock muffler). You can use a 2¼" inlet-outlet muffler with a reducer on the inlet and the outlet connected directly to the tailpipe. If you measure it yourself, post up the measurements with a picture please.
