I want to install the door sills but in the northeast I'm afraid to install in this cold weather incase they won't stick. Should I wait for warmer weather or put them on now?
3.35 L 4X4
-AND-
SLAYER1
You should be ok to install now, clean surface well.
Good luck!
Take them off and bring them in the house to warm up for a day. Use plenty of Dawn dish soap and a soft bristle brush to clean them, Dawn will get rid of all the grease, oil, etc. Dry them off. I used some rubbing alcohol and wiped them down to make sure everything is really really clean. I used 3M molding tape to stick mine on.
What Jim said...by take them off he means the OEM plastic ones now on the car, they will pull right off; so that both original and new pieces are warm. Dennis
GOD bless my friends, Paula, Cheese(Rex) and Alex and all those still with us.
Semper Fi
SUPPORT THE WOUNDED WARRIOR FUND
2012 HTRDR Lincoln MKT AWD Twin Turbo SHO Eco boost MOTOR
04 DTR "FruitPunch"5/17/04 Living with the "LEMONADE" in Ed's garage...
TRILOGY EATON #110 11-25-05
TRILOGY Twin Screw #003 Thank you MCM & JERRY BARNES
Install by THE STOOGES
ASS TUNE by LIDIO
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
--Winston Churchill
i like it when its warm and sticky lol
I got mine, I'm also attempting to put some type of protective gloss, I'll be waiting for warmer weather and to also prevent any of this years salt on it.
"Damned if I do, damned if I don't!"
Member #8831
MERIDEATH aka "Purrrty Mean" was born on June 20, 2002.
Production #1685 of 7,838 and is #1685 of 7093 Black Beasts.
Delivered July 27th 2002, she revealed herself.
Unable to be tamed by her 1st owner, she was left to roam about & raid in search of plunder.
Through the pillage she became mine on January 23, 2008 and since then...
"She's tryin' to make a Devil out of me!"
-"TaKe 'Em D0wN!" TRILOGY TwinScrew #209 / TS0019-
I'd wait for warmer weather. Or remove the parts, bring them inside, let them warm up, then apply the sill covers. Wait until the sill covers are stuck on good, then go put the parts back on the car.
11.98 @ 115 mph"Comfort, Class and Hair on Fire Performance."
I put mine on about 2 weeks ago while the car was in the garage about 43 degrees. I used alcohol to wipe the plastic off and some pressure and mine stick fine.
Voted #2 Display at MVV, Best of Show N/A at Carlisle 2010, Best Display at Carlisle 2011, 2012, 2013, Best Display at MVIX, Best Display and Best of Show N/A at Carlisle 2014, Best Display at Carlisle 2015
Capital Area Marauders Member (CAM)
03 Silver Birch 300B Built 6-2-03, Adopted 6-24-03, Sequence# 7604 of 7838--Color Sequence# 306 of 418
American Racing "Rogue" (ROUSH RR05) Chrome Wheels +25 Rear, +35 Front, Stock Tires, Custom Trunk Organizer, Lidio's Tune, Flowmaster 40's, K&N CAI, KVR Rotors /Hawk Pads, Tint 35%, Ford GT Coil Covers, KB Dead Pedal, Reinhart Automotive Pro-Gard, Euro Front Plate "SILVRBULLET"and /or "03 MM 7604", SIRIUS Satellite, Rear Spoiler, SS Inserts, SRP Pedals and Sills, Colex Caps.
cam·ma·rau·de·rie
Pronunciation: "käm-'maräu-d(&-)rE,
Function: noun
Etymology: American Mercury family, from Cam Marauder comrade (Member)
: a spirit of friendly good-fellowship of Marauder Enthusiasts
Remove existing sills and take both in the house to warm up. Clean existing sill with denatured alcohol or Ronsol lighter fluid.
Born 03/04
Adopted on 01/03/05
Now Procharger boosted #04
Did you remove the original stick tape (looks like insufficient coverage across the back of the aluminum sills) that was attached to the sills?
If so, did you put on wider & longer pieces of the 3M tape?
I've never installed mine because I read stories of them coming "un-stuck" and falling off in parking lots.
These are so on my list of things to get.
No Matter Where You Go, There You Are.
So how are they attached to the car? is it double sided tape, or sometype of clip that you can disengage???
3.35 L 4X4
-AND-
SLAYER1
3.35 L 4X4
-AND-
SLAYER1
