Results 1 to 15 of 21
Thread: rear fascia and tail lights
    Jan 2009
    Miami/Jacksonville, Fl
    im trying to get rid of the reflector on my 99. so do the MM or CVS rear fascia and tail lights bolt directly to the MGM?
    ...thanks
    Should fit no problem. If i was you i'd get the parts of a cvpi in the junkyard and night shade the tail lights.
    Problem solved and solved cheap.
    Apr 2006
    Montreal,Quebec
    Just paint over it
    Jan 2009
    sounds good to me. thanks.
    Aug 2008
    chicago
    noooooooo you cant just swap the rear from a MGM to a CV rear. you will have fitment issues i think the bumper needs to be replaces as well
    you can get the same result just by painting it
    too much crap on the car to list it all
    http://www.cardomain.com/ride/2958325
    ON
    CV facia to MGM is ok but you will have a gap in the bumper cover.
    MGM facia to CV is not ok because bumper covers are different.
    Jan 2009
    ...ok sounds like i'll be painting.
    so do i jus typical sand, prime and spray?
    Aug 2008
    chicago
    you could or you can use niteshades on the tails, this way you can keep the reflectiveneseseses of the rear fascia and it will alow you to controll how dark you want to shade the back. or if you want to completelly make it black than yea, sand, primer, paint, clear, wetsand and you will be golden!!!
    Jan 2009
    Quote Originally Posted by sanco View Post
    out working on the car i seen an idea to do with the fascia, i might try it out. but please fill me in on these nightshades if u would.
    Apr 2007
    Central MA
    Quote Originally Posted by mgmsleeper View Post
    Its pretty much clearcoat with a little black in it... you can tint the tailights a little or a lot depending on how many coats you want, but unlike paint, it is transparent when light is behind it..... Black tailights light up red.
    4257 of 7839 03 300A- SOLD
    2006 Ford Fusion I4 5 Speed
    2004 Mach 1
    Jan 2009
    Quote Originally Posted by hot-rauder View Post
    thanks. will look into it
    Apr 2007
    Central MA
    If you want it to look like a MM, paint it. If you want it to look like a tinted tailight panel, niteshade it.
    BTW for Niteshade to look actually black, you must clear coat it. Otherwise its an off green color.
    2004 Mach 1
    Sorry to steer you wrong, i allways thought the rears were interchangable.
    Jan 2009
    not trying to clone the MM, jus was trying to get rid of some of the reflector. im still thinking on what to do. i appreciate the info tho
    Jan 2009
    its cool
  1. Crossing fingers for a Marauder, black rear fascia panel
    By P71_CrownVic in forum Marauder Parts/Misc. Wanted
    Last Post: 03-04-2008, 10:57 PM
  2. 2006 Tail Panel on 2003 Mercury Grand Marquis?
    By xtcbct in forum Shop Talk
    Last Post: 05-08-2007, 06:36 AM
