At what RPM should I set the shifts on a stock Marauder?
Thanks,
Thanks,
For WOT, start at 6200 1-2, 6000 for 2-3. See how that does you.
300A
born 08-27-02
Adjusted air in and air out.
400+ timeslips.
Its actually better to wind out 2-3 to about 6400 so it puts the car back in the SWEET spot after the shift.
Sounds awesome, will try that after the headers.
Thanks,
1-2 at 6200 and 2-3 at 6400 is AWESOME
I still need to try it with the long tubes, I am sure it will be the bestest
Thank you,
