Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: Anatomy of a Ported Short Runner Intake
  1. #31
    Quote Originally Posted by Glenn View Post
    In all honestly, what does the IT really contribute below 5,000 rpm to launching off the line - HP? It's a top end mod!
    Glenn Ford
    no
    When I launch off the line I preload my TC to 2,500+ and after I top out 1st gear my Marauder never sees less than 4,800+ rpm.
    So, for drag racing, Naz's intake would work great.
    It's the daily driving, idle -> 3,000 rpm torque that worries me.
  2. #32
    tmhutch Guest
    Glenn Ford
    no
    Once an engines volumetric efficiency has been maximized with available bolt-ons, the only way to achieve more power is by increasing efficiency at higher RPM's. It's what serious hot rodders have been doing for decades. If a person wants they can capitalize on the high RPM efficiency with more gear, but it's not neccessary. With this intake MM's can now utilize better cam profiles as well. This intake opens up power potential not previously available to the MM crew. 12's will go down easy.
  1. Ported Short Runner Intake Results!
    By nazman in forum Nazty Performance
    Last Post: 06-12-2009, 08:01 AM
  2. 4v Engine Head info.... Detailed...
    Last Post: 01-20-2009, 05:24 PM
  3. PHP Ported Intake Manifold?
    By BruteForce in forum Exhaust
    Last Post: 03-02-2007, 09:05 AM
  4. Ported Marauder intake for sale
    By DEFYANT in forum Community Discussion
    Last Post: 02-19-2005, 09:29 AM
  5. Upper/Lower Intake Mods
    By SergntMac in forum Shop Talk
    Last Post: 10-05-2004, 06:16 PM
Tags for this Thread
