My Air Susp light came on last week so I went up to the Meineke that I work at during the weekends to scan my car for codes. It said that there was a problem with the air suspension pump relay. I swapped out the relay to find that it was not the problem and with a little more research and testing the pump I found out that the Control Module behind the glove box seems to be the problem. I called the Ford dealership to see about getting one and the price is $242.83. It seems that the dealership is the only place to get one and I wanted to confirm this. Durring these hard times (hours cut at main job) $245 is a good bit of money to spend for me, so I wanted to see if this is my only option? I did see the post for adjusting the air ride manualy and I may do this till I can afford a new control module. What have you guys found to be the best route in getting a control module? Thanks in advance!
Lee
