Originally Posted by
RF Overlord
This time, he asked a reasonable question. Either give a reasonable answer or don't bother posting.
A CVT in a 302 HP/318FT-LB/4400 lb Marauder?
Reasonable answer: NO!
BTW: CVTs don't have gears...maybe he should do the slightest amount of research before asking "reasonable" questions.
