View Poll Results: Which one....
Voters
33. You may not vote on this poll
  • Have the motor BUILT by reputable shop setup for power adder (only choice Vortech)
    3 9.09%
  • MMR Street Mod 950 Big Bore Stroker 5.3, Stage 2 Cams, Stage 3 Heads FRRP 302 Mod Block NA
    16 48.48%
  • OEM Remanufactured Dealer 3 year 100k warranty
    14 42.42%
Results 1 to 15 of 21
Thread: Over analyzing my motor options?
    Nov 2007
    NorCal
    OK fellas my little brain hurts.
    What should I do?
    1. Have a reputable builder re-build my motor (setup for power adder) Force Fed Performance. $$
    2. Buy a long block from Modular Mustang Racing (MMR) so many choices within this options. $$$
    3. Go back to OEM 3/100k warranty - Ford Dealer $
    $=Coin
    Input is appreciated.
    2003 Mercury Marauder 300A
    FRPP BOSS50 Block w/MMR 900S Stroker 5.3L DOHC 324ci 10:1cr - (321rwhp/360.5rwtq) - Tuned by AED
    2006 Ford Mustang GT
    FRPP FR3 Handling Pack|FRPP X Pipe w/GTA Exhaust|Steeda CAI|Hurst Shifter
    (289rwhp/307rwtq)
    2003 Chevrolet Suburban 2500 LQ4 6.0L LT 4WD
    Cognito leveling Kit, Fox 2.0, BFG KOA2 Radial All Terrains, Magnaflow, K&N and 4.10 gears
    Bossier City, La
    To make a logical choice you need to tell us what is the intended application(s).
    1. Daily street use, NA. 3 to 400 hp
    2. Occasional strip, NA, 3 to 400 hp
    3. Weekly strip, NA, 3 to 400 hp
    4. Daily street use, S/C, +/- 400hp
    5. Occasional strip, S/C, +/- 400hp
    6. Weekly Strip, S/C, +/- 400hp
    7. Any application, >450hp
    Brain hurting yet?
    Nov 2007
    NorCal
    Quote Originally Posted by Aren Jay View Post
    I would analyse your choices for several years then ask everyone here then think aobut it then think some more, then I would ask many real questions which if they seem far fetched actually will help me find that one special answer that is or has eluded me until I know which is the right choice. Then I would do something else.
    Really ask anyone.
    I keep meaning to join the procrastination society.
    Ok but really what do you think
    (289rwhp/307rwtq)
    Nov 2007
    NorCal
    Quote Originally Posted by pat View Post
    Brain hurting yet?
    Yes...my dilemma is
    I am thinking Daily street use and occasional strip. My problem is I live in Cali and to make over 400HP its going to have to be blown or have a BUILT BEEFY NA motor.
    The CARB # that the Marauder slipped under is a Vortech kit for the CrownVic and GM. I dont know if I want to build a motor add the power adder then have to take off because the the technicality.
    (289rwhp/307rwtq)
    Bossier City, La
    I'm running a stock motor with a Paxton Novi, 10 LB boost (Vortech) no intercooler, 50 shot nitrous and making 400 HP (more or less) and all is fine.
    77 K miles, go to strip a couple of times a year, 4-6 runs.
    The rebuilt motor should do you fine and save you bucks. A proper tune will keep the motor in one piece (so to speak). Good gas, regular maintenance, etc, etc.
    A built motor does not equal power/speed but speaks more to reliability and potential.
    I voted OEM replacement.
    Good luck
    Port Charlotte, FL
    Quote Originally Posted by bcastro View Post
    Yes...my dilemma is
    In the vin system, my Marauder always comes up as a GM.
    If yours is an early car, that my be how it shows up for you.
    Check that out.
    Are there any "engine swap" rules that come into play here?
    California, being the Pinko, Commie, insolvent, state that it is may have a rule for that too.
    04 Crown Victoria Sport
    1995 F150 4x2 4.9 5spd
    If you can force yourself to be content with 400 rwhp the OEM may be the best bet. When you put the blower on it you void the warranty so don't count on that 3yr/100k doing anything for you.
    Another good option since you're planning for a blower anyway would be to get a factory remanufactured '03-'04 Cobra engine. That would give you room to grow (up the boost in the future). The '03-'04 Cobra engine looks just like the Marauder engine so it should be easy to pass inspection. And if you can get the dealer to install it you should be able to get the warranty too.
    I had a bad experience with MMR so I would shy away from them. Some others have had good experience with them but I can only speak from my own experience.
    If you have a good local shop that may work out. I've had mixed results from that option, too.
    Jun 2008
    How about option #4:
    Ecoboost V6.
    You think I'm kidding, but we talked about this last night at the dragstrip...
    Quote Originally Posted by adam/cleveland View Post
    Ecoboost V6.
    That would never get past the emissions inspection.
    a buddy of mine also had a bad expirience with mmr so be carefull. other wise id say if your only gunning for 400ish hp roll with a stocker
    Nov 2007
    NorCal
    FordNut,
    Thanks I think...my head hurts more Did MMR do your stroker motors 5.3 in your sig? I think the only safe options is OEM. The shop that I am considering doing the work is fairly close to Ford OEm budget wise if I dont go crazy with the options.
    (289rwhp/307rwtq)
    TULSA OKLAHOMA
    According to how rich you are= how much risk you can AFFORD to take. As was mentioned MMR is a risk. So is a local rebuilder. May just be in my area, but I've never heard of a rebuild lasting near as long as an OEM factory motor. If mine goes out I will let dealer do OEM replacement with factory warranty. If you need more power do what everyone are doing now.
    Nov 2007
    NorCal
    Quote Originally Posted by O's Fan Rich View Post
    Check that out.
    Yes everything has to have a CARB EO# if aftermarket. With that said as long as it passes smog and they don't see anything visually your usually home free. Depends on the smog station. As far left as people perceive CA to be most of the state is red except The Bay Area and LA (voting isn't weighted the same across the state). The Central valley from north to south is much more conservative.
    Any how 30 Billion Dollar deficit = state might be desperate for money and REALLY go after people who knows at this point. Sacramento is all Partisan Politics so nothing gets done. Our state budget is due but nada....IOUs and checks that you cant cash until October!
    (289rwhp/307rwtq)
    FordNut,
    No, they didn't do my buildup but I got some of the stuff for my head upgrades from them. Didn't meet the specs they claimed when they sold it to me, then they charged me a restocking fee for their false advertising. Their super-duper cryo-treated oil pumps have destroyed a few motors when they shattered too. And several people over at modularfords.com have had problems with mmr engines.
  1. more options in the store?
    By Black_Noise in forum Site Questions and Suggestions
    Last Post: 01-07-2009, 07:40 PM
  2. NA options
    By Aren Jay in forum Community Discussion
    Last Post: 06-14-2008, 05:58 PM
  3. MM options:
    By Peter in forum Community Discussion
    Last Post: 05-22-2008, 09:53 AM
  4. 460 Ford Motor (1972 Police Intercepter Motor)brand New!
    By hitchhiker in forum Community Discussion
    Last Post: 01-03-2005, 08:14 AM
  5. Options
    By ron460 in forum Community Discussion
    Last Post: 11-13-2002, 11:12 PM
