If you want to start planing your own project and pick and choose what you want to order for paint. Here is the link to VHT so you can start looking for part numbers to order and what is available.
http://www.vhtpaint.com/index.html
As most of you know I planed to dress up my engine and had a poll on one of the choices of colors to go with the main work. Just as a note for the one's that may ask, with out a break down of all the prices this project is costing me in parts and paint a little over $800.00.
Verses the $1,200.00 it would have cost me alone to have everything powder coated both the base color and the high gloss finish and still have to buy all of the gaskets cleaners and missalanius incidentals. So the $300.00 for the paint was a much better way to go cost wise and the electricity to cure the painting stages.
The main reason for starting this project was due to my putting in a rear head coolant flow kit in.
There were no surprises taking the top of the engine appart aside from 1. In the 2 rear intake ports you could obviously see that the stems of the intake valves were a little discolored from running on the hot side at times.
Looking at the valve stems in the next cylender up on both sides there was a noticable difference in color of the stems.
Now other than an occational show off here and there in the almost 40,000 miles my car has seen it has been well taken care of and not abused. So I was surprised to see this condition to say the least.
Anyways I plan to document the work and condition of things and show all of the before and after work as I promissed a few people on here. And also what it looked like before I started the work.
I will start off with what the engine looks like torn down and how much parts there are every where from the car and the stuff needed to do the work. So here are a few pictures now.
BTW as you can see from the cam's and valve area it is spotless so as others have said you can not beat how well the synthetic oil works on these engines.
As I get a bit further in the project I will show you the end results of each part. So look for more pictures and info. As you can see in the last picture all of the parts both old and new as well as all of the high temp paint I am going to be using as well.
BTW I also got all brand new seals from Ford for this project nothing old is being reused what so ever including the sensors seeing it is all apart and out in the first place. So there will be no reason in the near future to deal with this stuff again. Also doing a new Thermostat and gasket as well.
A special note / sugestion. You have heard how much of a pain in the butt it is to take the Passenger side Cam cover off?! There is one more thing you can do to help make it a bit easier to take it off and put it back on. There is a wireing harness that wraps around the Cam Cover and gets inbetween the AC/Heating box and it. It is taped to a steal reinforcment bar that is held onto the back of the head with a single nut. Use a quarter inch drive wratchet and a 13mm socket and take that nut off it is brass in color. Then you can slip the steal bracket off of the stud and move that harness down below the cam cover and out of the way. Just remember to put it all back after putting the cam cover back onto the head.
