Results 1 to 10 of 10
Thread: Wipers and washer fluid going on thier own
    Feb 2006
    middle of iowa
    So I followed advice of members here. Thier thinking was along my lines, I had just washed the car, then 1 minute later the wiper starting going on thier own, then the washers started spraying on thier own. So I went after the wiper control module located right on the wiper motor.
    I removed the wiper cowl and wiper motor and trans, removed the module from the motor and cleaned with electical contact cleaner, and ran a small bead of RTV around the edge of the module case in hopes of keeping water from getting in, cause it did, not much junk buildup on the module, but did have water sitting around the connector and motor area.
    Anyways, threw it all back together, reinstalled wiper motor fuse (7.5 amp under steering wheel) and plugged back in the washer pump, 3 minuted later they started on thier own again.
    I callled the local FOMOCO and priced the module, not available seperate from wiper motor.
    So its $160 + tax I guess unless anyone has any other ideas.
    Guys???
    Long Island, NY
    Seems to be a common problem.
    Check with Big Dog Jim.
    He had a similar issue with his wipers.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    i paied 100 for a referbed unit from a local place. its been good to go for the last 2 years or so.
    Feb 2006
    middle of iowa
    local place as in parts store, like oriellys, advance auto, NAPA, etc.... or Ford store?
    sry, it was a "parts plus" store. i doubt you have them out that way
    Dec 2004
    Orlando, FL area
    When I had wacky wipers (but not wacky washer) on the 2003 MM under ESP the dealership replaced the wiper motor and some kind of newer wiring assembly that was associated with the wiper motor. Sorry my memory is so vague. I have the paperwork somewhere, but cannot find it easily.
    White Lightning Kiarauder:
    Black Thunder:
    Sequence number is 39 of 3213
    Traded in 12/12/10
    XCalibrator2/Reinhart tune
    Sequence number is 37 of 327
    Martyo's Garage!!!!!
    I am on my 3rd wiper motor due to the wacky wiper Gremlins. All covered under warranty. Haven't had a reoccurrence in the past 2 years. Problem is with debris plugging the drain hole below the wiper motor .... dayum tree crap.
    There is a TSB out on this ... Wiper motor and pigtail/wiring was replaced under TSB 05-04-09. The drain hole should be enlarged some to reduce the possibility of clogging. Parts listed below. Hope you can find a good deal.
    Parts listed:
    6W7Z-17508-AC Motor A 137493
    3W7Z-17A477-AA Wiring 812722
    Dec 2004
    Orlando, FL area
    Quote Originally Posted by Bluerauder View Post
    Parts listed:
    Yeah, that's it, yeah! I knew someone would come through with the part numbers!
    Black Thunder:
    Traded in 12/12/10
    Feb 2006
    middle of iowa
    So am I the only one who has had the washers go off with the wipers?
    Quote Originally Posted by Black_Noise View Post
    Nope. That's the way mine started the first time. The wipers went on and the washer just kept pumping fluid til it was empty. A woman behind me in a VW Passat got really PO'd 'cause she thought I was squirting her car on purpose. For a minute, I thought she was gonna blow a gasket.
  1. OEM TB, Wipers, Washer, H2O Pump FS
    By FordNut in forum Marauder-specific Parts for Sale
    Last Post: 08-11-2009, 05:07 PM
  2. Washer fluid coming on at random
    Last Post: 01-13-2009, 08:38 PM
  3. Brake Fluid change- Power Steering fluid spec
    By juno in forum Steering, Suspension & Brakes
    Last Post: 03-05-2006, 05:13 PM
  4. Heated Washer Fluid
    By DEFYANT in forum The Lounge
    Last Post: 01-17-2006, 08:55 PM
  5. low Washer fluid sensor
    Last Post: 12-29-2004, 05:39 AM
