Results 1 to 8 of 8
Thread: window operation with no engine
    Nov 2005
    Davenport, Ia
    I have a marauder that has no motor or trans in it and i am about to ship it. Before i ship it i have to put the windows up. Is there any way to do this without removing all 4 door panels? I tryed just hooking a battery up, that was a no go. Also tryed jumping the main window switch connector and that didnt work, maybe i did it wrong.
    2003a Black Marauder- Procharged, Cobra exaustmanifold, Flowmaster 40s, 4.10s, Widend rear rims and other stuff.
    2003a Black Marauder- Nitrous, SCT tune, Detroit TruTrac with ford 4.10s, JLT CAI Totaled in storm 6-18-09
    2003 Yamaha R1
    Should work with a battery installed and key turned to acc or run.
    Hiram, Georgia
    What he said.
    could it be that the battery was grounded to the motor before and since its out you have no ground? i cant remember where the battery was grounded when i relocated it plus, im not great with electric. just a thought
    Nov 2005
    Davenport, Ia
    just hooking the battery up and turning the key did not work. It has to be a ground just which one am i looking for lol
    2003 Yamaha R1
    Las Vegas Nevada
    Quote Originally Posted by Impala Slayer View Post
    +1 ground, But if you jumpered the window motor correctly "not the switch" it should not be a problem?
    Try connecting a jumper wire from the battery negative post to the chassis. Maybe the battery grounds to the engine, then the engine grounds to the chassis? With the engine gone the circuit is open?
    kinda what i was thinking
  1. Open/ closed loop fuel operation
    By jdenning002 in forum Shop Talk
    Last Post: 08-15-2009, 05:35 PM
  2. Operation: Market Garden Paintball DFW area
    By MAD-3R in forum The Lounge
    Last Post: 08-31-2006, 03:29 PM
  3. Cooling Fan Operation
    By Eric91Z in forum Shop Talk
    Last Post: 03-22-2006, 04:51 PM
  4. Going in For A Little Operation.
    By TheDealer in forum The Lounge
    Last Post: 08-11-2005, 12:06 PM
  5. Fog light operation
    By Constable in forum Community Discussion
    Last Post: 07-05-2003, 08:57 AM
