Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Stock subwoofer speaker replacement in OEM enclosure possible?
    Dec 2004
    Franklinville,NJ
    Sorry everybody. I am sure this has been discussed many times over but can't find threads under all my searches so far. Looking to replace my OEM subwoofer speaker with aftermarket but installing in the OEM enclosure. I thought I read some time ago that there were 2 sub speakers made that would fit the factory enclosure with maybe only minor modification if I'm not mistaken. I don't mind adding a small mono amp if needed but was looking to keep as much of a stock appearance as possible. Any thoughts?
    2004 Silver Birch (Sold 10.20.2008)
    2004 DTR (Sold 2.2.2010)
    2004 Silver Birch (Adopted 2.5.2010)
    This one is a keeper!
    I took out the OEM unit and installed an Infinity Basslink. No teeth shattering bass but enough for me.
    My install
    Dec 2004
    Franklinville,NJ
    Thanks, I like that idea. Looks nice. How did you mount though? Did you have to drill I assume? I agree with you. Just looking for respectable, nice full quality sound, not trying to rattle the car apart. For example, I also have an '08 F150 that has the factory audiophile set-up. Super sweet!! Just perfect, not overkill but has plenty of lows, mids, and highs all from the factory. That's the kinda solution I am attepting to acomplish here. Thanks for your response, I appreciate it.
    Just a simple swap to the 06 Escape audiophile would help you, especially if you hard wire an Ipod to drive it. Plug and play, and looks factory. Thats all I did besides elcheapo kicker 6x8 2 way's and any member who has had a sampling cannot believe how good it sounds now! The Ipod really helps drive a better sound!!
    I tried a couple of replacement drivers, best I found was Infinity.
    Quote Originally Posted by drj02 View Post
    It is secured to the shelf by screws. Have to be careful as the gas tank is located below. Was very careful drilling and used just the right length screws.
    I'd also replace the anemic factory speakers and add tweeters to the front sail panels. A new headunit is also good. I have a Pioneer AVIC-D2.
    Nov 2009
    Oakbrook, il
    Just wondering if you do fit the Ford Escape cd player would your CD changer still work?
    A legend quote a True Ride can not be no Rider without a Marauder
    Finally Eatonized by ZackZillaaaaaaaaaaa!
    Cardomain link: http://www.CarDomain.com/ride/3380944
    A bank is a place that will lend you money if you can prove that you don't need it
    Quote Originally Posted by bawazir View Post
    I don't think so, but here's a link with some extensive info:
    http://www.mercurymarauder.net/forum...ight=escape+CD
    No, it won't, but you now have a 6 disc in dash as a replacement.
    St. Louis, MO
    For those of you who've used the basslink, do you happen to have the other legs that came with it that allow you to mount it vertically instead of horizontally? I threw mine out years ago when I put my basslink in another vehicle but now I need a pair.
    The Dirty South
    Go with the Pioneer 8" shallow sub Model#ts-s841d it will fit with a little tweaking and you can keep the stock amp and enclosure.
    Quote Originally Posted by hidperf View Post
    I'll check, but I think I threw them out.
    Longwood, FL
    Pioneer TS-SW841D is the full part #.
    2003 300B
    VIN: 677166, #6738 of 7839
    built: 2/13/03
    wrty start: 5/28/03
    84,197 on 02/21/08
    95,776 on 02/21/09
    109,301 on 02/21/10
    121,447 on 02/21/11
    125,925 on 02/26/12
    130,375 on 01/01/13
    134,831 on 2/4/14
    149,441 on 2/24/18
    Dark Blue Pearl, #128 of 327
    Aug 2009
    edmonton, alberta
    hey I noticed when you hit preset 3 and 6 together it plays each speaker seperetly and sub 1 is hooked up and when it says sub 2 nothing, we have 2 outputs for subs?
    Hawaiian Islands
    Great info...
    Thanks guys!
    Aloha
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
  1. For Sale Stock sub, enclosure, and amp
    By mherman18 in forum Marauder-specific Parts for Sale
    Last Post: 01-10-2010, 08:48 AM
  2. For Sale OEM Radio, subwoofer (amp and enclosure)
    By jjsrant in forum Marauder-specific Parts for Sale
    Last Post: 09-18-2009, 11:35 PM
  3. Has anyone upgraded their subwoofer speaker?
    By GeoffK in forum Shop Talk
    Last Post: 11-21-2008, 11:11 AM
  4. Replacement for factory sub speaker
    By SID210SA in forum Community Discussion
    Last Post: 03-29-2006, 07:54 AM
  5. speaker replacement
    By joflewbyu2 in forum Community Discussion
    Last Post: 04-11-2003, 04:12 PM
