Added new steering wheel switches.
https://get.google.com/albumarchive/...aGk1ZS9AdVnC-D
https://get.google.com/albumarchive/...8yt1pEXbQFM1oJ
Washed the SB with a sample pack of Meguire's Ultimate car wash I got at Carlisle. Car looks worse than when I started. Total garbage product. Has anyone tried the Mr. Clean ( I think that's who makes it) with sheet drying action. Trying to avoid water spotting as much as possible.
I use Girot's and take the nozzle off for the sheeting final rinse.
Yesterday, repaired the front speaker connectors for the driver's door speaker. Cleaned and recharged the K&N CAI filter. Been busy lately don't want to neglect her no more than I have to.
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15
SOLD
Redid the PCV and breather system.
This is the only thing I've used which will actually have a spotless rinse. I use the DIC-20 system. Use this for rinse only or you'll burn through the resin tanks fast
https://crspotless.com/
2063/3214
5377/7838
Tooled around town for a while and then replaced both front window switch covers. Broke the little tab that holds the back of them down a couple years ago. Lookin' good now and won't make that mistake again!
Upgraded fuel system
Upgraded from P1 to D1
Added Headers
All done by Mo's Speed Shop
Sent from my SM-G950U using Tapatalk
Build# 1979/3214
Year 2004
300B
Ext. DTR
Int. Dark Char
FINALLY BOOSTED!!!
Emissions check. Passed again in ohio with the rear O2s turned off in the tune.
2003 300A
Eaton Swapped by Curless
Brake Upgrade
Mo's Tune
JLT Intake
Addco Sway Bars
ADTR Coil Over Suspension
SW Headers and Exhaust
Accessories By FastBlackMerc
4.10 Gears
Aeroforce Gauges
Pantherlights Headlamps
There are currently 4 users browsing this thread. (0 members and 4 guests)
