Page 2 of 37 FirstFirst 12345678912 ... LastLast
Results 16 to 30 of 550
Thread: Eaton Swap Parts List Thread
  1. #16
    Oct 2009
    Arkansas
    Quote Originally Posted by swordfish View Post
    I'll add the cobra cooling tube and bolts. for under the intake
    Cooling tube F8ZZ-18B402-BA
    Screw N807959-S309
    Bolt N807309-S437
    This tube under the intake.
    Mark E. Sword
    1964 Falcon AFX clone (Rommy Hammes)
    1970 1/2 Falcon Cobra
    2003 Marauder DPB #5 of 328
    http://www.mercurymarauder.net/forum...ad.php?t=63629
  2. #17
    Got it, thanks for the clarification.
  3. #18
    Quote Originally Posted by bob6364 View Post
    You will need to cut and weld the original water crossover tube
    or use the Cobra cooling tube and bolts.
    Screw N807959-S309
    Bolt N807309-S437
    This is confusing. Sould read something like this:
    You will need to cut and weld to make a coolant crossover tube by combining the original crossover tube with a Cobra crossover tube.
    Heater coolant return tube: Either smash the OEM one with a hammer so it clears the lower intake or replace it with this one that fits properly:
    Screw N807959-S309
    Bolt N807309-S437
    03 MM 300B Silver (Mostly stock, wife's car, 300k mi) FPG # 7053 of 7838 or 49 of 417 SB
    03 MM 300B Silver, Stock, 50k mi FPG # 7134 of 7838 or 89 of 417 SB
    01 F150
    00 F150 4x4
  4. #19
    Nov 2007
    Eastern,Connecticut
    I was partway with the update when the mrs call out "supper"...so off I went I forgot about that nasty little tube under the intake thanks....
    2004 Black Mercury Marauder
    2057 of 3213
    Lidio 93 Octane Tune
    4.10 FRPP Gears
  5. #20
    May 2007
    Massapequa Park
    Just need to modify the marauder crossover, you dont need the cobra tube and the marauders. You can do it with both though if you wanted. I followed impalaslayers example shortened the factory crossover about an inch in height and length. Welded up the end that ataches to the thermostat, removed and rewelded the mounting tabs to the botom of the crossover so they bolt to the heads, moved the the other coolant hose nipple(the barb on the passenger side of the crossover tube) so it doesnt hit the belt tensioner. I made a tee from a couple of metal hosebarbs from the hardware store belive there 1.5 barbs. The tee conects the upper radiator hose to the thermostat.
  6. #21
    Nov 2007
    Eastern,Connecticut
    ok everyone refresh...see how that looks
    2057 of 3213
    4.10 FRPP Gears
  7. #22
    Nov 2007
    Eastern,Connecticut
    Quote Originally Posted by tjl006 View Post
    Hmmm...I guess if the name of the game is get superchargered for short money and the cobra tube really isn't needed maybe I should delete it.
    2057 of 3213
    4.10 FRPP Gears
  8. #23
    I'd like to see Zack's new idea on this piece...
    01 F150
    00 F150 4x4
  9. #24
    May 2007
    Massapequa Park
    I would also like to hear zacks idea does it involve any parts from evenflow?
  10. #25
    Nov 2007
    Eastern,Connecticut
    I will be afkb for an hour...have to powder coat a bracket for someone....
    2057 of 3213
    4.10 FRPP Gears
  11. #26
    Throttle Bracket 2R3Z9728BA and Cable 2R3Z9A758AA
    Intercooler pump (new or used doesn't matter)
    I used my MM cable, did others have to switch?
    Gotta come up with some sort of bracket for the pump.
    Need an intercooler reservoir & cap and some sort of bracket for it.
    01 F150
    00 F150 4x4
  12. #27
    Im gonna start experimenting in about 2 weeks.
  13. #28
    Nov 2007
    Eastern,Connecticut
    Wow this is going good...more,more gimmee more.
    2057 of 3213
    4.10 FRPP Gears
  14. #29
    Extra Battery Tray, Battery Cable
    I used a different battery altogether, but I think Dave was able to use the stock battery.
  15. #30
    Nov 2007
    Eastern,Connecticut
    I was just thinking the same thing zack...also i'm going to start injecting pics....i will rezize them and neaten up as we go along
    2057 of 3213
    4.10 FRPP Gears
  1. Eaton Swap
  2. Eaton swap marauder on ebay
    Last Post: 01-31-2010, 02:49 PM
  3. thanks to gortch for the eaton swap brackets!!
    Last Post: 09-07-2009, 04:45 PM
  5. Good start on an Eaton Swap
    By bob6364 in forum Other Parts for Sale
    Last Post: 01-05-2009, 09:22 PM
