Been searching and can not find the answer anywhere I know I read the reason once, but why exactly can we not run a #6 lower?
If it's cheap and reliable it isn't fast
If it's cheap and fast it isn't reliable
If it's fast and reliable it isn't cheap
I believe bill runs that. Using a tensioner bracket like this
Those were the days.........
DANG THEY'RE CUTE!!!!!!
Smile and Nod
I love THIS bar
Is the cobra aftercooler needed for this swap
guys is this the correct bracket for the eaton swap ?
SEE LINK
Eaton M112 Supercharger ✓
Intercooler ✓
Lower intake plenum ✓
Coolant Intake Manifold ✓
TB Intake Plenum ✓
Throttle Body ✓
Cobra air intake tube ✓
Accelerator cable bracket ✓
Fuel rails ✓
39lb. injectors ✓
Cobra heat exchanger ✓
lower Metco pulley with hub ✓
Intercooler reservoir ✓
90mm Lightning MAF ✓
MAF to filter adapter plate ✓
Conical air filter ✓
Custom Gortch Brackets ✓
Heat Exchanger brackets ✓
Intercooler pump ✓
Intercooler pump bracket ✓
Ribbed idler pulley ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
New accessory belt ✓
Cooling tube ✓
IAT sensor ✓
Thank you Mr.silversnake !
Intercooler ✓
TB Intake Plenum ✓
Throttle Body ✓
Fuel rails ✓
39lb. injectors ✓
Intercooler pump ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
Cooling tube ✓
IAT sensor ✓
HELLO!!!!!!!!!![]()
Smile and Nod
I love THIS bar
Guys i'm thinking of buyn a JLT for our MM, but when I swap to Eaton, do I have to buy a CAI for the cobra too? or the MM CAI well fit just fine.
Intercooler ✓
TB Intake Plenum ✓
Throttle Body ✓
Fuel rails ✓
39lb. injectors ✓
Intercooler pump ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
Cooling tube ✓
IAT sensor ✓
OK guys I already have the cobra 90mm maf do I still need the SCT BA-3000 maf also?
If so please explain in simple
Intercooler ✓
TB Intake Plenum ✓
Throttle Body ✓
Fuel rails ✓
39lb. injectors ✓
Intercooler pump ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
Cooling tube ✓
IAT sensor ✓
No.
Builder Of Badassery
Thanks, but here's another questionI need a crank pully kit but I'm confused with these tow pulleys!
One is for F-150 Lighting and the other is for the Cobra !!
Is there's a different ? I see the diffrent only in some metal pieces, Is that really matter ? I already have the upper pulley BTW.
Sorry for asking again and again but I search and couldn't find an answer for it
Thanks
Intercooler ✓
TB Intake Plenum ✓
Throttle Body ✓
Fuel rails ✓
39lb. injectors ✓
Intercooler pump ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
Cooling tube ✓
IAT sensor ✓
You want the Cobra one. A few members are even running this setup https://www.lightningforceperformanc...ang_Cobra.html . I believe Mo's is a vendor for the LFP products.
2003 300A #5377 130,XXX Miles
Drilled and slotted rotors from Ebay
JLT
Stainless Works Long Tube Headers and 3" catback.
Mo's Tune
12.073 @ 118.43 (Nitto 555)
Drag racers prayer:
