Page 5 of 37 FirstFirst 12345678910111215 ... LastLast
Results 61 to 75 of 550
Thread: Eaton Swap Parts List Thread
  1. #61
    May 2007
    Massapequa Park
    Flat idler has nothing to do with the alternator, you have to use it for the bracket to work there in no other option. Grinding the alternator has to do with belt alighnment i guess. I did not have a problem with that.
  2. #62
    Oh lord!
    You grind the alternator because the idler pulley will make contact with it if you dont!
  3. #63
    Oh lord!
    i didnt grind anything
    Now you are making me wonder If I ground anything! I know Im crazy, but this is crazy.
  5. #65
    Oct 2009
    Arkansas
    Hey, Dave what idler pulley did you use? I'm pretty sure I've got the same brackets as you.
    Mark E. Sword
    1964 Falcon AFX clone (Rommy Hammes)
    1970 1/2 Falcon Cobra
    2003 Marauder DPB #5 of 328
    http://www.mercurymarauder.net/forum...ad.php?t=63629
  6. #66
    Quote Originally Posted by swordfish View Post
    i used the one that is removed from the passenger bank. you replace that one with a ribbed idler.
    i know on the ones you sent me before you would have had to grind it but it seems Terry has changed the design a bit
    I can sleep tonight, thanks Davie.
  9. #69
    May 2007
    Massapequa Park
    Oh Lord So much grinding so little time. The only thing me and dave(I belive) had to grind was some material of the alternator bracket because it was rubbing on the water pump pulley. I dont know if terry fixed that on his new brackets.
  10. #70
    Quote Originally Posted by tjl006 View Post
    that is correct, 2 mins with the belt sander ans it was good to go. i did tell Terry about it when i first ran into the problem and sent him pics so hopefully he corrects the next brackets he makes.
    May 2007
    Massapequa Park
    I think the issue was that on his set up I belive the lip on the waterpump pulley was removed, ours still had the lip so that rubs the bracket. No lip on the pulley would make it so you could chane the belt without taking the alterntor bracket off.
  12. #72
    Oct 2009
    Arkansas
    So I need to get a 8 rib idler? Any part number?
    Mark E. Sword
  13. #73
    yeah i had a lipless pulley but decided not to use it.
    no sir a six rib. i have the part number in the shop but i know Zack has it as well. if he dosent get it by tomorrow i will post it here
    May 2007
    Massapequa Park
    XR3Z-8678-BA theres the number Dave is correct its the width of six ribs but the pulley is not ribed, its flat, hence the name flat idler
  1. Eaton Swap
  2. Eaton swap marauder on ebay
    Last Post: 01-31-2010, 02:49 PM
  3. thanks to gortch for the eaton swap brackets!!
    Last Post: 09-07-2009, 04:45 PM
  5. Good start on an Eaton Swap
    By bob6364 in forum Other Parts for Sale
    Last Post: 01-05-2009, 09:22 PM
