What is the story with the guy who put a Tremec 6 speed in his Marauder? How can I put one in mine and the most important question... how much?
the tremec TKO/3650 physically bolt up without too many modifications. The transmission crossmember bolt lines up exactly with our 470Rws. a T-56 would require you to elongate the bolthole in the crossmember, but it wouldnt require you to hack up the crossmember. A new driveshaft is required also. Now comes the hard part. Pull the carpeting front seats and console out of the car. Cut the hole in the floorpan for the shifter, and modify the console. Grab the fixed pedal assembly out of any crown vic, town car, or mercury, and bolt it in in place of your moving pedals. Now grab the clutch pedal assembly from a SN95 mustang. A brace has to be welded to the firewall side on the other side of the pedal bracket, and the pedal actually must be moved up slightly, because if you line it up with the gas and brake it actually hangs too low, and contacts the floorpan. Next have a bracket machined in a horseshoe shape, and drill your firewall on the driverside to accept this. This bracket will be what holds the master cylinder for the clutch assembly, and I believe the slave cylinder sits on the tremec somewhere. Replace the flexplate with the cobra flywheel, and if you are going to get an aftermarket clutch assembly now is the time to do it. Bolt the clutch together with all associated bearings and forks (if you know your way around a manual transmission you know what im talking about, if you dont, print this up and give it to a shop cause you probably shouldnt be doing it.) Bleed the fluid assembly and test the clutch modulation. Finally, your car wont start when this is done. Contact reinhardt, or whoever it is that does your chip, and tell them to eliminate the automatic transmission function. Now your car should start, and you can enjoy your 6 speed. I did this on my impala SS before it was wrecked, big cars are fun with sticks too.
2002 Crown Vic LX sport *SOLD* but still in the family
1985 monte carlo SS 477 rwhp T56 - parted out to go to law school
On the hunt for the Marauder I tried to get back in 2002!
P.S. on the downside, you will not have a neutral safety switch like basically every other MT equipped car since 1970. If the clutch is engaged, the car will start, and you could turn your living room into a drive through.
(I almost did this with my impala shortly after i finished it.)
Zack...You got all of this, right?
I read the above instructions and went out and did mine during lunch!
2003 MM 300A
Born June 18, 2002
Adopted Christmas Eve, 2002
First Factory Rebuilt Ford P.O.S. Engine at 81,000 miles
Second Factory Rebuilt Ford P.O.S. Engine at 101,000 miles
Ford Racing 4.10's
Reinhart/XCal2 Custom Tune
Reinhart Underdrive Pulleys
K&N Conical Air Filter
Reinhart Exhaust with 18" Magnaflows
Silencer Removed
Bosch Micro Edge Excel Wiper Blades
Bob White Red Bumper Inserts
Lone Star Beer in cup holder
Fellowship of Christian Cowboys
license plate bracket
God and the soldier we adore, In times of danger, not before.
The danger gone, the trouble righted, God's forgotten, the soldier slighted.
Cynicism is the smoke rising from the ashes of burned out dreams.
If my automatic ever goes out, this is what's going back in!
Cheers!
I would love a stick in my MM, but since it's my daily driver and I often get stuck on Houston freeways, crawling along, I'm afraid my left leg would be out of warranty before long!
2003 MM 300A
Born June 18, 2002
Ford Racing 4.10's
Silencer Removed
Stunning piece of re-engineering. Never under estimate the resourcefulness of the individual with a wrench in his hand and a gleam in his eye.
How about the Aviator 5 speed auto, will it fit and work with stock crossmembers and basic reprogramming? What are the gear ratios with the Tremec 6 speed and the Aviator 5 speed auto?
Ex Marauder owner,
May 5th, 2003, March Bought new
February 2007, Installed Trilogy,
March 30th, 2011, sold to a great home.
Great car, great people, great times, wonderful memories.
One note to add: The t56 has a reverse lock out solenoid. It prevents you from shifting into reverse when you are moving forward. When the t56 is OE, the computer or other source disengages the lock at the appropriate time. You will have to wire in a switch to manually operate it. Or, if you are clever enough, you can tap into some sort of speed sensor (such as the speed sensitive volume on the radio) and have it open at 0 mph.
Second, here is one source of aftermarket clutches. Depending on which flywheel you choose, there are many sources. But, this one is popular lately. http://www.specclutch.com/
Hey Big Dog would go for this one!
Member # 383.
2003 Marauder Black.
Build 8/13/02
Launched 9/28/02
Sold May 16, 2018
#3,646 of 7,839 black '03
I respect your advice and caution here Joe, but I have some of my own.Originally posted by Warpath
Y'all want to drive a manual tranny MM? LEARN HOW TO DRIVE IT!
Don't Cobras(and Mustangs) have cable clutchs?
