Results 1 to 11 of 11
Thread: Master Cylinder and Brake Bleeding
    May 2005
    Amissville VA
    Who here has replaced their master cylinder and what were the symptoms that lead you to do so? Was it worth it?
    Secondly, I've searched many threads about bleeding brakes. Who has successfully bled and flushed their brake lines after such a job with no ill effects or air in the ABS unit?
    Here's the deal, when I brake I hear a slight noise in the pedal assembly, and the brakes feel spongy. At a stoplight I notice the pedal will gradually sink down (not all the way but more than I would want in a car), and as it does this if I hold my foot steady I can tell the brakes let up a tad.
    To me this indicates the master cylinder is letting fluid lightly seep past the seals. Brakes are fine otherwise and in normal driving haul you down from speed no issues.
    But this doens't feel right and therefore I need to get it fixed, don't like having anything not feel right on the brakes.
    I've replaced boosters and master cylinders on cars before, bled plenty of brakes, done brake lines even hard brake lines I custom made. So I am fine doing this job but the ABS unit and flushing the system is what worries me if it can be done by a DIY'er in their garage without the scan tool.
    Am I better off carefully replaceing hte master cylinder and then letting the air bleed up and driving a few miles to the dealer for a full on flush/bleed?
    Trilogy #112 (self installed)
    12.99@106.2mph (for now)
    Apr 2005
    Queens NY
    I have the same problems as you. I replaced the master, changed the fluid and bleed the brakes 3 times.
    My brakes still suck. If I wanted to, I can push my pedal all the way to the floor even with the new master. Im also noticing a slight hang up in my brakes when coming to a stop.
    I'm thinking I have to take my car to the dealer and have it bled through the ABS.
    Its irritating that my old POS crown vic could out stop my Marauder.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Hiram, Georgia
    You can do this yourself.
    You will need a large bottle of fluid, plus a little bit extra.
    Make sure that you get teh correct master (their is a TC version (slightly more expensive) and a non-TC version.
    I did mine 2 weeks ago when I was faced with even worse symptoms than yours because I ignored the sympstoms you had.
    It is well worth it. If I did it again, I would spend the time and money on replacing teh rubber brake lines.
    Do this with a helper to push the pedal and bleed the brakes until teh fluid flows clean.
    You will be pleased with the results.
    Let me know if you have any questions.
    Apr 2005
    Queens NY
    So the rubber brake lines are the reason for lousy brakes?
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Jul 2006
    South Haven, Mich.
    They were on my Merc. Paul. Changed them and what a difference!
    [SIGPIC]
    May 2005
    Amissville VA
    Quote Originally Posted by Pops View Post
    Just changed or upgrade to SS?
    Anyone know if there are SS kits available currently? I don't see much on the TCE subforum, but haven't asked yet. I may focus on the Master cylinder first...
    May 2005
    Amissville VA
    Marty - thanks! Sounds like a job I will tackle within a few weekends then.
    Feb 2005
    Clermont Florida
    I replaced mine cause it was leaking. It wasn't easy to find a new one. I called about 7 local dealers before I found one. Be warned... they are Marauder specific. The Vic/GM ones have the front and rear fittings reversed.
    Performance
    Dress
    LOC: Clermont Florida
    Definitely go with the SS brake lines.
    The Dirty South
    +1 on the SS lines. The spongy feeling is gone after I did mine as well.
    Apr 2005
    Queens NY
    Have a link where I can get them?
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
  1. Wanted To Buy Brake booster and master cylinder from under 40k mile Marauder
    By Stranger in the Black Sedan in forum Marauder Parts/Misc. Wanted
    Last Post: 04-26-2010, 09:15 PM
  2. Master Cylinder Leaking!!!
    Last Post: 07-10-2009, 06:05 AM
  3. Master Cylinder Leaking
    By BigCars4Ever in forum Shop Talk
    Last Post: 04-12-2008, 05:29 PM
  4. master cylinder
    By eric jones in forum Shop Talk
    Last Post: 09-06-2007, 02:35 PM
  5. Master cylinder and pump
    By Lowndex in forum Shop Talk
    Last Post: 02-18-2007, 12:02 PM
