Results 1 to 2 of 2
Thread: Throttle Position Sensor
    Oct 2009
    Middle East - SA
    Good evening all
    how are you ??
    My marauder have two codes number one is 1151 that mean i have a proplem with o2 sensor so i bring i new one but i do not install it i leave the codes ..
    i check agine i found i have two codes 1151( Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2) and 1125 this code mean the Throttle Position Sensor Intermittent so i change the sensor but i find the new one broken so i Return the old one but before i Return it i check the obd-II and i found one code P0122 Throttle Position Sensor/Switch A Circuit Low Input i think that mean the sensor is broken right ??
    and i Noted the codes about o2 sensor gone is there any relation or what please help me becouse i Return the old one and check agine and i 1151
    Have you checked for a possible vacuum leak? For the TPS, you should check the voltage at the plug, with key on, engine off, by back stabbing the harness with a volt meter. The volts should be close to 1 volt at idle position, contine to manually move throttle body to fully open position while watching your volt guage. It should be smoothly climbing the more you open the throttle and should read near 5 volts at fully open. If I recall, it is the top and bottom wires that you want to check. Been awile, search the net if you don't get a signal.
  1. MAF sensior position
    By SlkMerc in forum JLT Performance
    Last Post: 07-12-2006, 06:22 AM
  2. Replies: 4
    Last Post: 05-22-2004, 11:27 AM
  3. throttle position sensor wire help
    By darebren in forum Shop Talk
    Last Post: 05-18-2004, 05:45 PM
  4. Autotap question: throttle position
    By TripleTransAm in forum Shop Talk
    Last Post: 05-14-2004, 10:03 AM
