good morning
in witch cars is the Marauder engine moreover?
good morning
Marauder 300A from 2003, one of two in Germany!
#6020 of 7093
2MEHM75V93X658764
WITH LPG
"The exact engine is only in the Marauder. You can find the same engine with small changes in the intake and front timing cover in other vehicles, 99-2000 cobras, 03-04 Mustang Mach 1's, and Lincoln Aviators. You can find them in Late model Lincoln Continentals, but since that is a Front wheel drive car, the bell housing bolt pattern on the block is different and can not be used in a rear wheel drive vehicle."
'03-'04 Mach1 is the closest match.
