Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
Thread: Heinous billet rear control arms
    Feb 2009
    Upstate NY
    Thumbs up Heinous billet rear control arms
    Installed yesterday. Nice upgrade! Car feels a lot more sure footed much better in corners and acceleration.
    got them here: http://adtr.net/sunshop/index.php?l=...t_detail&p=147
    Really nice looking too - for those of us with BLACK MM's
    03 300A - Number 1727
    The Dirty South
    No Pics of the install?
    Feb 2009
    Upstate NY
    I can post some if you want tonight. Man what a difference. It's "like a jmod for your suspention"
    The Dirty South
    Did you ever do sway Bars on the F&R?
    Feb 2009
    Upstate NY
    Nope I have the factory bars on front and rear. The Energy Suspension graphite impregnated polyurethane bushings are way better than the factory ones. Dare I say it feels like a Miata?
    Apr 2005
    Queens NY
    According to Heinous.....
    • CNC machined from 6061 T-6 aircraft grade aluminum. Milled pockets and holes for the lightest possible weight.
    • Anodized black with the chamfers cut to show the aluminum.
    • Energy Suspension graphite impregnated polyurethane bushings installed for long term noise-free service. No grease fittings needed.
    • Improves handling in acceleration, cornering and braking. Makes the car feel more sure footed.
    • Fits all 98 plus panthers
    • Perfect for light to medium modded Panthers. For higher horsepower vehicles, I’d suggest stepping up to the Metco bar
    Step up to the metco bar? So they are admitting that their product isn't as strong as the metco product. So you would have to spend over $400 for the metco set-up down the road if you go SC.
    You could go from mild to wild with the Sparta arms for $25 cheaper then Heinous and over $100 cheaper then Metco and out perform both in your choice of color. (shameless plug)
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Feb 2009
    Upstate NY
    Not sure about that - Spectragod has Henious billet arms with 472 rwhp and no problems. How many guys are SC with stock CA's ?? (a ton I'm sure) Henious arms are way beefier than stock.
    Nothing against Sparta - but I wanted billet. They are $100 less than Metco and just as good or better IMHO.
    Jun 2008
    Waukesha, WI
    I think it's apples to oranges. Any tubular or billet control arms are leaps and bounds above stock.
    They look nice.
    I'm still very happy with my Zack & Mac tubular control arms.
    From the first run with revised pinion angle!
    Don't forget musclemerc's "old school" boxed control arms...
    Feb 2009
    Upstate NY
    They look nice.
    Thanks!
    Nothing against him. I'm not that crafty (can't weld) .
    I'll be really happy if they drop me into the 13's
    The Dirty South
    Shhhhhhh! I'm not wearing my flame suit!
    Those CAs are cool looking with the machined & chamfered holes...
    +1!
    They look nice.
    You opening up that 'can of worms' again?.....
    The Dirty South
    Not until you do the sway bars and a full ES endlink and bushin upgrade.
    Quote Originally Posted by babbage View Post
    Do you have the E.S. endlink part numbers?
    I've got a set of swaybars in the garage...
  1. Heinous Motorsports Control Arms F/S
    By DJCV in forum Other Parts for Sale
    Last Post: 08-19-2009, 05:41 PM
  2. Rear control arms
    By Hauser717 in forum Shop Talk
    Last Post: 07-31-2009, 07:01 PM
  3. rear control arms
    By steve h in forum Steering, Suspension & Brakes
    Last Post: 11-03-2008, 11:57 AM
  4. Heinous Motorsports Control Arms have arrived!
    By offroadkarter in forum Community Discussion
    Last Post: 09-16-2008, 10:19 AM
  5. Rear Control Arms
    By TAF in forum Shop Talk
    Last Post: 07-24-2003, 09:32 AM
