Results 1 to 15 of 22
Thread: Collector Flange hardware
    Jun 2007
    Woodstock Georgia
    I have Kooks header w/the 3 bolt 2.5" flange. About every 2-3 weeks I have to go under the car and tighten up the hardware. I have tried lock washers, nylon lock nuts, loctite, and it still seems to start leaking again after a few weeks.
    I'm using the reusable soft aluminum gaskets and they seal great I just keeping having issue with the hardware loosening up over time. Any suggestions would be greatly appreciated.
    If I ever order new headers it will be with the ball flange for the ball/cup type seal.
    04 SB MM RIP 4/24/09
    03 SB MM (the new girl)
    Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq
    Mr Gasket Ultra Seal gaskets and Mr Gasket collector bolts with locking nuts.
    The Dirty South
    You coule always strike the top of the bolt with a small chisle to booger the threads
    Oct 2004
    Do to high temps & nylon lock nuts are a bad choice. As for the type of loctite you used you would have to use specific high temp loctite for it to be effective. Just use a 2nd nut to lock the 1st.
    Nov 2007
    Eastern,Connecticut
    Double nut them.
    2004 Black Mercury Marauder
    2057 of 3213
    Lidio 93 Octane Tune
    4.10 FRPP Gears
    May 2003
    Waterloo, IA
    Quote Originally Posted by bob6364 View Post
    Double nut them.
    That's what she said!!
    Nov 2007
    Eastern,Connecticut
    Quote Originally Posted by TooManyFords View Post
    I wish you would have told me sooner...she prolly ain't in the mood no more....
    2057 of 3213
    4.10 FRPP Gears
    Feb 2005
    DC MD Area
    I got SW Long tubes and they attach with a band clamp right from the end of the header to the Cat....No leaks at all
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
    Use what I said. They're not nylock locknuts, and they're not castellated, they are the flattened style. They come with the bolts, in a Mr Gasket pkg of 3 each.
    Jun 2007
    Woodstock Georgia
    Hey Fordnut are these the ones your talking about http://www.summitracing.com/parts/MRG-3413/?
    In the description they don't say anything about locking so I wanted to make sure before I went to over to my local shop to order them.
    I also found these from stage 8 http://www.summitracing.com/parts/STG-8950/ which I may just use with the gaskets you suggested. I'm doen w/the soft aluminum gaskets. I don't think it is the hardware that is the problem but the soft aluminum Percy's gasket constantly expanding and shrinking.
    Quote Originally Posted by cougar9150 View Post
    That's the ones. I find them at Advance, Auto Zone, and O'Reilly's depending on which store has them in current stock. That's where I get the gaskets too.
    Jun 2007
    Woodstock Georgia
    Thanks fordnut, I picked everything up a couple local stores but had to use longer bolts. Seems the flange on the x-pipe side is overly thick as the 1" bolts barely poked a couple threads through. Not enough to safely get a nut started.
    My old aluminum gasket had really become distorted and started hanging out the flange on the bottom side. I am really surprised how distorted it is, making me think that my exhaust is running overly hot and explains why the latest high temp coating on the headers is already peeling.
    A/F was good when I got the tune so I shouldn't be running lean. I'm going to have to get an IR thermometer and see what the actual temps are when the engine has been running for awhile.
    It shouldn't peel if it's properly applied.
    Jun 2007
    Woodstock Georgia
    I know and this is my second go round with the same guy. The problem is that a buddy of mine had his 69 Camaro headers done at the same time as my second attempt with the higher temp coating. His are holding up fine and mine are peeling again. Not sure if it something with this set of Kooks, my car exhaust running hotter (it's turbo black coating so it should take the heat),or the coater himself. Mainly it is starting to peel at the bends in the tube and where a the primary tubes and the collector are welded. Not anywhere that may have gotten something on the headers during install.
    I've already decided I'm going to eat the cost with the first guy and bring them to Brother Powder Coatings for next time I do a tear down. It will probably be once I am getting ready to install my eaton setup because I think I want to install a new motor at the same time. Going to go with traditional ceramic coating instead of the colorized temp coatings.
    Oct 2008
    Ocala, florida
    yesterday i change the oem gasket that was leaking on the passanger side and i noticed my collector bolts were loose also.
    thanks Brian, now im going with Mr Gasket.
    Phil it seems like you and i are hooked on taking these LT's in and out.
    im on my sixth time. hope to be the last time, unless the engine blows and i get an Aluminator.
  1. For Sale Engine Hardware
    By Vortech347 in forum Marauder-specific Parts for Sale
    Last Post: 03-04-2010, 11:52 AM
  2. hardware grade
    By burt ragio in forum Shop Talk
    Last Post: 03-01-2010, 10:44 AM
  3. Gaskets and hardware.
    By cougar9150 in forum Exhaust
    Last Post: 08-23-2009, 11:57 AM
  4. Taking home the Hardware!
    By AzMarauder in forum Community Discussion
    Last Post: 10-10-2005, 12:40 PM
  5. More hardware for Mercman!!
    By MERCMAN in forum Community Discussion
    Last Post: 09-18-2004, 04:39 PM
