Results 1 to 6 of 6
Thread: Non OEM Radiator Fan???
    Blog Entries
    2
    Running a Centrifugal requires using an open radiator fan shroud that reduces the fan efficiency. I have tried moding the OEM Rad Fan Shroud but it puts the fan motor too close to the S/C Head.
    Has anyone used a different rad fan set up then the OEM? If so what are your coolant temps with the a/c on when the ambient is above 95*? What fan or fans did you use and how did you set them up?
    Thanks,
    You might be able to get the '06+ CV/GM fan to work. It's a little shallower than the '03-'04 but the electrical connector is different. Also, the FIT setup uses the OEM fan but mounts it upside-down. You may try that.
    ask TMF, he has dual fans with what looked like a custom made shroud tat covered the entire rad
    Blog Entries
    2
    Thanks for the suggestions.
    I forgot about FIT mounting upside down, old age???
    I think RRSusiki may have 2 pushers?
    Hawaiian Islands
    Brian is correct.
    Mount it upside down, cut two tabs and extend the wires, then your good to go!
    Aloha
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Apr 2009
    michigan
    I used the mustang fan and shroud but I plastic welded parts of the Marauder shroud onto it to cover the radiator. Driving stop and go traffic in 95 f temps car ran fine. Evan with a few trips into the boost, coolant and IAT temps were fine
    My garage
    http://www.mercurymarauder.net/forum...=view&id=10419
    04/30/11
    1/8 mile 7.7430 at 89.24
    1/4 mile 12.16 at 110.66(calculated)
  1. Radiator Fan Quit
    By Juice in forum Shop Talk
    Last Post: 07-30-2010, 11:59 AM
  2. Radiator Fan Motor Clicking
    By Joey3571 in forum Shop Talk
    Last Post: 07-05-2010, 10:19 AM
  3. Radiator fan will not shut off
    By djv5150 in forum Shop Talk
    Last Post: 06-26-2010, 11:44 AM
  4. What a crappy day! (radiator fan/motor went up)
    By ctrlraven in forum Community Discussion
    Last Post: 06-12-2008, 11:36 PM
  5. radiator fan assembally
    By marauderboi in forum Community Discussion
    Last Post: 06-19-2007, 05:09 PM
