My blend door is having problems. I have read the codes on my eatc at got 024.
Does anyone have the procedure on how to manually engage the actuator or any other way of testing it. I do not know what color the wires are that run to the actuator.
Problem resolved, please ignore.
what was wrong cause im having a issues with it now im thinking the blend door needs to be replaced
2003 MM, JLT inktake, 98 cobra cams, adjustable cam gears, SW headers Long tube high flow cats stock back, 4:10s, dyno tune 305rwhp, JMOD, SS inserts, lowerd 1in,
1995 buick regal 3.8 daily driver
Yes, please tell how you resolved. I'm getting desperate over here!!
'03 Marauder - "The Backup" -----> SOLD! Now Marauderless
Adopted June '09
K&N FIPK, Magnaflows, SCT Tune, Steeda Underdrive pulley, EMP/Stewart high volume water pump, intake spacer, Autolite XP104's
4/9/11 Remanufactured Marauder engine installed @ 64,400 miles by GNB Auto Repair, Astoria, NY
Learn from my ignorance....CHECK YOUR OIL!!!
'72 Oldsmobile Cutlass Supreme - "The Hulk"...gone to the great junkyard in the sky
'70 Oldsmobile 442 - "The Keeper"...now alive and kicking
I would suggest PM,ing Ken cause he is not on here much since going to the darkside LOL
________________
Marauderless
Adopted June '09
I am unsure of why my car was behaving like it was. It was stuck on hot for about a day so I took the eatc out after running the diagnostic checked all the vacuum lines etc. Plugged it back in and it worked ever since.
What issues are your cars experiencing? Maybe it could be worn eatc solenoid o-rings? Mine were original in my 03. My 04 on the other hand had the eatc problem RIP.
You're still here!!
Mine blows only hot (really hot!) from correct locations. A/C compressor works and system is charged. I know it's a blend door problem. I've replaced o-rings on original EATC, had blend door motor replaced and now have installed other EATC with o-rings upgraded....all no good.
When I 1st start the car and run diagnostic, I get code 024 and 025. When cleared and run again, I get 024 only. If I sit still and clear the codes a few times, I have gotten cold air to blow. As soon as I start driving, it goes hot.
Another member is parting-out an '03. I've already requested the blend door, motor and plenum. Dealing with this for almost 2 months now, happened right when I put her up for sale. Ever try to sell a car in the summer with no a/c?!? !
Any and all insight welcomed at this point.
Adopted June '09
One would have to be quite crazy to spend hours upon hours to install a USED Blend door Actuator!! Brand new from Ford is not all that much $$ good for a while!!
2004 Mercury Marauder 300A Black
Build date: 9/26/03 552 of 3214 2004's
105K miles Second Owner. Charcoal interior Heated Seats All stock with Lidio 91/93 Octane tune 14.85@95.63 with 93 tune only. 96 cobra intake cams in the cellar, pondering TR6060 swap.
Pictures
2004 Crown Vic LX 150K Silver Birch with Light flint leather. Auto dim mirror, EATC and steering wheel radio controls. 21mm marauder rear sway bar and wood steering wheel. MM head unit , MM subwoofer coming (really) 04 P-71 80 mm MAF/ airbox 04 p71 zip tube 04 P-71 PCM swap. Heated mirrors with silver birch endcaps coming!!
Pictures
1996 Lincoln Town Car Signature
Touring Edition 250K 2004 PI 2V swap complete! Sold
Pictures
74 Laguna S-3 Project car Original 400 Small block
Since the blend door motor is a ***** to replace I'd only get a new one.
