Results 1 to 15 of 17
Thread: Rear Axle Seal Replacement
    Hello there,
    I searched but could not seem to locate the advice I was looking for. I hear tell it's a bit tricky to replace my right rear outer axle seal. I've done it on Fords and Chevys before. Anything I should know? Do I need to pull the ring/pinion cover and remove a clip or do I remove the 4 bolts at the outer axle and simply pull it out like my old Fords?
    Also, I need to replace the rear trans seal. Now I don't think there's any more to that besides pulling the driveshaft - sound right?
    Thanks a bunch,
    BILL
    04' DTR Loving every minute
    ont he axle, you gotta pop the cover off the diff, remove the center pin and pull the c clip. then its easy from there on out. not sure aobut the trans
    Feb 2006
    middle of iowa
    the output shaft seal, rear most of the trans, yep drop the shaft and then pop it out and pound the new one in
    Thanks fellas.
    I was told I need to put synthetic back in the differential. True?
    Rockford
    yeah use the friction modifier
    Quote Originally Posted by Bradley G View Post
    some synthetics already have it, just make sure when you buy it
    Derby City, KY
    What ^^He^^Said.
    Make sure the bottle has "LS" on it -> Limited Slip.
    Mike.
    Dec 2007
    Toronto, Ontario, Canada
    Regarding the diff fluid:
    when I used Amsoil many years ago in my 8.8 Mustang diff, I called Amsoil and they told me I didn't need to add it.
    "Barry's" the name;
    Drums and Cars are my game
    "I smash the pedal; air and fuel go in; witchcraft happens; I go fast!"
    "No question is stupid, if you don't know the answer!"
    2004 / Black / 1981 of 3214.
    #184 of 509 in black out of 1214 total in all three colors with the moonroof option.
    So if the bottle says Limited Slip or LS on it should I still add the friction modifier?
    Derby City, KY
    Quote Originally Posted by Bill Lalk View Post
    You should not have to unless you hear the clutches 'chatter' around corners (making a turn) so I have been told.
    Mike.
    Dec 2009
    If your axle seals are leaking, you might still have the defective axles.
    Contact Blackened300M he just did his axle seals and bearings a few months ago. Luckily his axles were in great shape but like previous post stated you may find some wear on yours so be prepared.
    If you are using a synthetic gear oil you don't need to add friction modifier.
    To remove the axles, you'll have to remove the diff cover to remove the "C" clips that prevent the axe from walking out of the housing.
    Jan 2009
    New England
    look closely at the condition of the axle where the wheel bearing rides. if it's all chewed up like this one, you'll need a new axle.
    while you've got the axle removed, you should consider replacing the e-brake shoes. the friction material has a habit of rust-jacking off the backing plate and falling off once a car gets to be several years old.
    here's a link to more pictures:
    http://www.p71interceptor.com/brakes...pictures/2005/
  1. Leaking axle seal?
    By Big House in forum Shop Talk
    Last Post: 02-14-2010, 06:01 AM
  2. rear axle seal
    By 4play in forum Shop Talk
    Last Post: 08-30-2009, 09:02 PM
  3. Oil leaking from axle seal.
    By Go Mifuni in forum Shop Talk
    Last Post: 05-14-2008, 07:51 AM
  4. HELP right rear axle seal...
    By rayjay in forum Shop Talk
    Last Post: 04-16-2008, 06:49 PM
  5. Rear Main Seal Replacement
    By Aeroman in forum Community Discussion
    Last Post: 01-14-2003, 05:03 PM
