So I fried my DB 250amp alternator after less than 3500 miles, has anyone done the same? Thanks
2003 300A
Build date 9/27/02
Sequence# 5244 of 7839
I have a few things done to it, Eaton swap next!
1993 Ford Taurus SHO-Every bolt on available...Awaiting a Turbo
2008 Ford F350 SD
1974 Ford F350 SCS
2011 Ford Flex Titanium, Ecoboost
www.cardomain.com/id/shofast
If you don't stand behind our troops; please feel free to stand in front of them!
Mine is still working fine.
Call DB, I'm sure they'll replace it.
It is still cover under warranty and I think they have awesome products, just wondering if this is common?
2003 300A
Build date 9/27/02
2008 Ford F350 SD
1974 Ford F350 SCS
No these are a quality unit did install the wiring lit. As well
I used one for 2 years, the regulator went out and I sent it back. They fixed it for free.
Damn, buddy, sorry to hear of the trouble. My understanding is that you had not yet upgraded the wiring ("the big three"). I'm not sure I understand how that could lead to a fried alternator. Do you think it could be an issue?
I'm installing my DB 200amp alternator next weekend, and plan to do the wiring upgrade at the same time. I'll be interested to hear your thoughts on this.
2003 Mercury Marauder
2007 Lincoln Town Car
1993 Crown Victoria LX
Looks really nice. For your engine ground it looks like you ran back to the firewall. Where did you terminate the firewall side of that ground wire?
Fastblack,
That is beautiful! I have upgraded my most of my wiring to 4ga, probably going a little bigger when I rewire everything. You have done and amazing job! I am also wondering about your engine ground. Thanks for the pics.
2003 300A
Build date 9/27/02
2008 Ford F350 SD
1974 Ford F350 SCS
I'm going 1 gauge on my wiring. I went looking for a crimp tool capable of doing 1 gauge and almost passed out when I saw the prices. I sure hope I can rent one at AutoZone.
2003 300A
Build date 9/27/02
2008 Ford F350 SD
1974 Ford F350 SCS
I used these to solder the wire to the terminals and then used heat shrink tube to seal and finish it off.
http://shop.ebay.com/i.html?_nkw=wir....c0.m270.l1313
Get the copper terminals at WalMart and the shrink tube at Northern Tools or Harbor Freight.
Awesome, thank you for highlighting that in the pic. I'll ground my engine to the same spot. I have copper terminals for the cable, but I've never seen anything like those solder slugs before. How do they work? Do you put the slug inside the terminal, heat it up and push the wire in? I was planning to just do a good crimp job and then use heat shrink tubing over the top.
EDIT: Nevermind, as my friend is always saying, "GTS!" (Google That sh.. errr, stuff). I think these solder slugs look like a great solution. Thanks for the tip!
