Results 1 to 15 of 30
Thread: air compressor or spring conversion?
    Jun 2010
    essextrash, maryland
    well, my compressor died and i talked to musclemerc about a new compressor, because IMO, hes the shat and knows his shat. he pointed me to arnott, and while i was checking the new compressor out, i noticed they have the conversion kit to springs. i manually pumped the airbags last night, and from what iv'e measured, both airbags are holding pressure. so heres my thoughts, ...im laid off, i just had my tranny go out 300 miles ago, the car has 107,500 miles on it, and i dont think the bags have ever been replaced. should i spend $190 on a new compressor and install it myself, or get the springs for $189, and attempt to install those? i dont have a lift, just a jack, and a simple ~160 piece craftsman mechanics tool set, do i need any special tools, or any tips anybody could provide that has done this? im assuming the springs will be the same although theyre meant for a merc. gran marquis. money is tight, and i dont want to spend any more cash than i need to. thanks guys--whitey
    Smithfield, Virginia
    Vroooom!
    WIN WIN!~ Zack
    The Heartland of Indiana
    salvage yard replacement would be a good alternative and less $$$$
    Rockford
    Post up for a used compressor, someone here has got to have one for you.
    The Dirty South
    The tool collection you have is more than adequate to do mosty anything on a MM let alone any other car, foreign or domestic.
    I agree, put out a WTB ad for the compressor and then just put a new drier on it. Swap out the parts and keep your car the way it was intended to be from the Mfg.
    You got my number if you need me.
    Good Luck!
    Jun 2007
    Woodstock Georgia
    Another alternative is a company called American Air Suspension (I think). Dennis Reinhart posted about them awhile back but I'm on my phone and can't find the thread. They sell refurbished compressors for about $140-150 and they have 2 year warranty I believe.
    04 SB MM RIP 4/24/09
    03 SB MM (the new girl)
    Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq
    Nov 2003
    Horntown, VA
    I cleaned up the printed circut board on mine over a year ago when mine went.
    It's been working fine ever since. I believe there is a thread with pictures somewhere on the site.
    Plate - "EVILMERC"
    Jun 2010
    mine looks pretty corroded, and when i removed the dryer, the tabs broke off. another question is, due to my ignorence on how the air line is supposed to be removed, i cut mine about 6" from the end that goes into the dryer. is there a way to reconnect the 2 pieces back together?
    Nov 2003
    Horntown, VA
    Try a hardware store or one that deals in hydraulics and get a compression fitting union for the tubing - bring a piece for size.
    They all look pretty corroded but if it doesn't work now what do you have to loose trying to clean it up!
    Oct 2003
    Beaufort, SC
    I would never convert to springs!!!
    Feb 2010
    Cincinnati, Ohio
    I replaced mine with the Arrnott Industries replacement almost a year ago with no problems. http://www.mercurymarauder.net/forum...air+compressor I love the air ride and I think after you install springs you will love the air ride too, and wish you would have fixed the air. I still have the old compressor minus the wiring harness. If it would help you out I will send you my old one free of charge. Maybe you can find someone that can rebuild one buy putting the two together. I know mine looks pretty bad but maybe there are some salvageable parts on it. Let me know if you are interested.
    Me too....
    Jun 2010
    krytin: where is the board to clean up? i opened up the part where the green wire runs to and it has a blue cylindrical thing, the part where the red wire runs to is corroded, the bolts wouldn't come off, if i need to get into that i'll try some pb blaster or wd40.
    sr271: i appreciate the offer, but i think i'll buy a new compressor, and save myself the time and possible dissapointment of it still not working...i can see it now...the wife "you've been spending all day on that compressor, and it didn't even work...when are you going to help w/ the baby.."
    to everyone else, if i cant fix the compressor myself with help from krytin, im going to hold out on purchasing one until i have the money, its pumped up and is holding pressure(even gained some height when i drove it and it warmed up). thanks for all the help.--whitey
    Oct 2010
    what ever you do do not convert to coil springs! thats like taking a porterhouse off the grill, only to replace it with a cube steak!
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jun 2010
    Quote Originally Posted by motown marauder View Post
    from ruth chris's to cracker barrel, lmao.
  1. Replies: 5
    Last Post: 06-30-2010, 06:33 PM
  2. 01 K/B Conversion
    Last Post: 01-24-2010, 07:35 PM
  3. DTV Conversion
    By FordNut in forum The Lounge
    Last Post: 06-14-2009, 08:13 AM
  4. 04 CV LX conversion
    By jdenning002 in forum Community Discussion
    Last Post: 05-13-2009, 11:07 AM
  5. Spring compressor for front shock replacement?
    By MMM2003 in forum Steering, Suspension & Brakes
    Last Post: 09-13-2007, 05:45 AM
