Where could I find the head volume of the Marauder in cc's? I'm looking to replace my blown engine, and need the data to confirm the compression ratio I'll get with the dished pistons in a shortblock I'm looking at.
Thank you!
Thank you!
MOD HISTORY:
-Lidio's Xcal2 flash, JLT CAI
12.81@107.78 Oct 02/09
-Ventilated Block Mod
Out of commission
-Rebuilt with:
-Widened rims
52cc's Flat top pistons should give you about 11.1:1cr
12.073 @ 118.43 (Nitto 555)
Drag racers prayer:
Also, 18cc dish pistons will net 8.5:1, and stock pistons had a 3cc dish. If you can, get pistons with 9-11cc dish, they should put it in the 9.2-9.5:1 range. You'll be likely to get 20-21* of timing with stock boost levels and room to grow without killing much torque in the meantime. When I was researching it that seemed to be the best bang for the buck using the boost limitations of the Trilogy with pump gas. With boost levels at the upper end of the blower efficiency, there should still be room for a fair amount of timing.
Keith,
03 Marauder
10.48:1 wth flat tops
