Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 58
Thread: BAP Installation with Pics
  1. #31
    Feb 2005
    DC MD Area
    Ok did a run a lil while ago..I couldnt get up to 5k rpm it was dark and the deer are out didnt want any mishaps....Base on what Im seeing the fuel pressure in the rails are up and down....Looks like I need another pump to stabilize that fuel with those 60lbs injectors pumping it out at a faster rate then stock. What ya think guys?
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
  2. #32
    Sep 2004
    Woodbridge, VA
    In the log on live link, right click just before you go WOT and drag the line out to when you come off the throttle. Then post that screen shot.
    Or email me the log file. Also if you want to try again. Go out and start off in first then shift to second manually and leave it there and roll into the throttle to WOT and get as high in the rpm range you can that way.
    ~Chris
  3. #33
    Feb 2005
    DC MD Area
    I forgot to turn the OD off too. That will help a great deal lls.
    2003 300A Black MM
  4. #34
    Feb 2005
    DC MD Area
    Update...I need to add another pump. I'm maxing out the pump over 4500rpm. Also my fuel rail pressure is all over the place. I'll be adding another 20amp BAP, another stock FPDM and another GT pump. Then I'll repost findings.
    2003 300A Black MM
  5. #35
    Nov 2006
    Langley, BC
    Quote Originally Posted by NATEHAWK View Post
    So what has happened? My car is on the dyno and running out of fuel pressue at 5800rpm with a BAP/ single GT40 setup making 405 rwhp.
    The dealership is suggesting an Aerodyne fuel pump. Where can I find details on the dual GT40 set-up?
    MOD HISTORY:
    -Lidio's Xcal2 flash, JLT CAI
    12.81@107.78 Oct 02/09
    -Ventilated Block Mod
    Out of commission
    -Rebuilt with:
    -Widened rims
  6. #36
    Feb 2005
    DC MD Area
    Just google it. They are all over the place. I think I may just go with a Dual GT Pump with a 40amp BAP and modded FPDM. Our fuel hats don't allow us to run wire to each pump separate. I think this is the most affective and simplest way to get more fuel and not blow anything.
    2003 300A Black MM
  7. #37
    Feb 2005
    DC MD Area
    Just purchased a 40amp BAP, Zone 5 Stage 2 modified FPDM, and another GT Pump to add so I'll have dual pumps. This setup should hold me to 600rwhp.
    2003 300A Black MM
  8. #38
    Maryland
    I'm running the same setup accept without a BAP, Heavy ga wire to the fuel pump hat. With a BAP you should have plenty of fuel! Good luck bro!
    601rwhp 592rwtq @19psi
  9. #39
    Aug 2007
    Bel Air, MD
    Thank you for the write-up Joe.
    I installed my BAP this weekend in the same spot but decided to mount it on the back of that bracket so the carpet would sit a little more normal.
    I placed the BAP on the front and marked the four mounting holes with a punch. Drilled through bracket where the holes were marked. Placed the BAP on the rear of the bracket and secured it with rivets.
    300A #507
    Trilogy #250
    14" Brakes
  10. #40
    Apr 2010
    Western Canada
    Quote Originally Posted by Darksyne View Post
    What a great idea, and it looks great too! There really is no need to access the BAP block itself after installation, so unless it needs to be changed out later, I actually prefer your method and might switch mine over when wire in my stereo in a few weeks. Thanks for the pic!
  11. #41
    Apr 2007
    Wisconsin
    I just installed my BAP as described here. Great write up! I notice that this is a bit different (in location and not wired up to the boost gauge) than the way described in the Trilogy manual... Is it safe to say that this is the "better" way to hook it up? and how important is it to run power directly from the battery?
    #3538 of 7838
    Trilogy #238
    Build date:8/14/02 - Bought:4/5/07
  12. #42
    Feb 2005
    DC MD Area
    Quote Originally Posted by Cougar_Marauder View Post
    No wires actually go to the boost gauge. You just run the vac hose that comes with it to the port on the back of the intake and straight to the gauge. If you decide to use the Hobbs switch then you could T-off to it and wire in to activate for the BAP to come on under a set boost psi. But most of us guys wire it to be on all the time.
    2003 300A Black MM
  13. #43
    Apr 2010
    Western Canada
    Both methods will work but based on what I've learned it's best to skip the vac hookup and to set the fuel knob permanently. This will provide consistent voltage increases to the FPDM which ultimately makes it easier for the ECU to learn a correct fuel pump voltage table. The ECU is able to dial the voltage back when there is less need for fuel; there is no need to have the BAP doing it.
  14. #44
    Apr 2010
    Western Canada
    I need to update this post a bit!
    If you are near or above the 450HP range, running a thicker power cable from the battery to the BAP is necessary to keep it sufficiently powered. Or at least it was for me with a GT40 pump. The factory wiring just can't carry enough current to feed the BAP.
    I have data logs to show this and will make some updates shortly.
  15. #45
    Quote Originally Posted by JoeBoomz View Post
    What gauge do you recommend?
  1. Installation pics of "Vynal Shades"
    By SID210SA in forum The Lounge
    Last Post: 01-12-2008, 09:16 PM
  2. Subwoofer amp installation - with pics
    By HwyCruiser in forum Shop Talk
    Last Post: 03-14-2004, 08:17 PM
  3. 4.10s Installation
    By M&Ms4Rob in forum Shop Talk
    Last Post: 03-17-2003, 03:53 PM
