Lower ball joint replacement
I need to replace a left lower ball joint on my '04 MGM. For you guys that have cut your front coils or done other suspension work, is replacing the lower control arm just a matter of compressing the coil and unbolting the control arm from the damper, crossmember, and spindle, or is there more to it? Just looking for any tips that might help.
I'm debating removing the control arm and having a shop press a new ball joint on my existing control arm or replacing the whole control arm.
04 MM Silver Birch/Light Flint, HS, TO, 6CD, #597 of 3214 (sold 5/2014)
06 MGM LS Ultimate w/HPP, Black/Dark Charcoal
04 MGM LS Ultimate
69 Marquis convertible, 429
95 F250HD 7.3 4x4
48 Ford F4
