Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 37
Thread: Traction Control Disable
  1. #16
    Minden, NV
    Habit for me as well.
    TRILOGY S/C #108
    2004 Mercury Marauder, Black/Grey
    Factory Sun Roof, Heated Seats, Factory Spoiler, Truetrac, 31 splines,
    4.10's, PI converter, Adco rear sway bar, Metco control arms, watts link and drive shaft loop, Kooks exhaust system, Naake springs, QA1 shocks, Widened factory wheels, Nitto's
    2012 Mustang GT, Sterling Grey
    Brembos, 3.73's, Kooks long tubes catless,
    Borla ATAK, MGW shifter. 2.8 L.C. Kenne Bell.
  2. #17
    Jan 2007
    Fort Wayne, IN
    The electrical engineer who helped me with it has named it the WV-1000.
    Wait for it....
    The warranty void-er 1000. Promises to void any warranty in record time.
    2018 F-250 6.7L Crew Cab 4x4
    2013 Dodge Charge R/T Daily Driver/Beater - All original 208K miles and counting
    Sold - 04 Marauder, Silver, Dark Interior, Factory Sunroof.
    Z-Tune, JLT CAI, Z&M Control Arms, KYB Shocks, BC4E Dead Pedal, Pro Guard, Sparta Watts links, R1 Slotted Front Rotors, Braided SS Brake Lines, Automatic Traction Control "Turner-Offer".
    4.10 FRPP gears awaiting install (on extended hold).
  3. #18
    Feb 2011
    Hawaii
    Quote Originally Posted by Green96 View Post
    IT WORKS! I will post up the solution and parts list tomorrow as soon as I can.
    Very interested & Waiting......
  4. #19
    Jan 2007
    Fort Wayne, IN
    I have attached the scematic.
    Vin goes to a switched power source (powered when key on, but not acc). I used fuse #14.
    Vout connect to the grey wire going to the traction control switch.
    The triangle connection goes to the black wire next to the grey wire (there are 2 black wires going to the switch - I think either would work but I have not checked).
    Parts list:
    Board - 1 needed - Mouser P/N 854-SB300 (www.mouser.com)
    Capacitors - 1 to 4 needed (C1) (I used 2)- Mouser P/N 647-UVR1H101MPD1TA
    Transistors - 2 needed(Q2&Q3) - Mouser P/N 512-KSC1845PTAQ
    Diode (rectifier) - 1 needed (D1) - Mouser P/N 512-1N4004
    Resistor - 1 needed (R2) - 10 KOHM 1/10 Watt minimim
    Resistor - 1 needed (R3) - 220 KOHM 1/10th Watt minimum
    The circuit basically holds down the button for a fixed time then releases. The button is still active, so in bad weather you can turn it back on. The more capacitors (wired in parallel) the longer it holds the button. each capacitor should give about 1.5-2 seconds of button push. I used 2 for about 4 seconds. If the button is held for more than 15 seconds, the light goes out and the button no longer works so do not exceed 6 capacitors. I will post pictures as soon as I get them downloaded.
    Attached Files Attached Files
  5. #20
    Jan 2007
    Fort Wayne, IN
    Some pictures for an interested party.....Sorry they are a little blurry.
  6. #21
    Apr 2011
    Statesville, NC
    pretty cool, i like making little dohickeys like this
  7. #22
    Jan 2007
    Fort Wayne, IN
    One important note. I ended up adding a 3rd capacitor after about 6 months of use. The number of capacitors determines how long the button is "held in". Most of the time 2 was enough, but I eventually had to add a 3rd to make it 100% reliable.
  8. #23
    Jun 2007
    West Houston,TX
    my panther was born without it
    2001 Ford Police Interceptor - Former Jan Jacinto College (Hou,TX) Campus PD vehicle, 79k current miles
    MODS:
    Law Enforcement equipment deleted, 20x8.5 Saleen Style's, 245/35R20 directionals, Ford Racing Performance Improved (PI) intake manifold, Power Plus 75mm TB, Zip Tube, 1" ported TB spacer, BOSCH platinum plugs, Performance aluminum radiator, Rear cats deleted, dual weld-in Flowmaster 10s, dual res-delete tips, red brake caliper kit, Pioneer Audio
    2004 Marauder - RIP
    2006 Grand Cherokee WJ - 4" long arm, 31 inch Nitto Muds, Flowmaster 10
  9. #24
    Derby City, KY
    Damn boys,...
    All this over choosing to hit a button?
    Good stuffs!
    Mike.
  10. #25
    Feb 2012
    harrison twp,mi
    Quote Originally Posted by MM2004 View Post
    Damn boys,...
    Good stuffs!
    Mike.
    Haha forever evolving
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
  11. #26
    Oct 2004
    Why that is a piece of work. Nothing better than being able to rotate tires. Time to take orders for a production run.
  12. #27
    Nov 2013
    New Jersey
    Maybe it would work to put a momentary relay tied to the seatbelt switch, so when you buckle up it turns the traction control off.
  13. #28
    Jun 2006
    Central New Jersey
    +1 I agree!
    Build Date 3/19/04
    Adopted on 10/19/07
    Seq#2102 of 3214
    #681 of 997 SBs
    #154 of 336 SBs with the moonroof
    Thanks Brian
    Member of The 100K Club 11/20/11
    Options-
    moonroof-heated seats-6-disc changer-trunk organizer-rear spoiler-mercury all weather mats
    Mods-Extras-Bling-
    Action Automotive-SS Inserts
    Auto Meter 4327 Oil Pressure Gauge
    Badgeless Grille(Thanks 03 Merc)
    Big Mike's Performance-"Sto n Sho" License Plate Holder
    Dead Pedal(Thanks lji372)
    Curless's Pedal Gear Repair
    Cruzer's-Arm Rest
    EATC Ungrade(Thanks JACook)
    Escape/Audiophile Radio Upgrade(Thanks shodude)
    Ford Racing M-7195-AOD Aluminum Trans Pan
    Innovative Interceptors-God's Head Valve Stem Covers
    J-Mod Valve Body
    K&N Performance Intake Kit{CAI}
    LCM Upgrade(Thanks Fastblackmerc)
    Marty-O Fender Badges, Tune & 4:10s
    Panther Lights HID Headlights
    Pro-gard Skid Plate
    Rear Cooling Head Mod
    Visteon Sirius Satellite Radio Setup(Thanks RoyLita)
    Weather Tech-Side Window Deflectors
  14. #29
    Dec 2015
    Remington, IN
    Struggling with the same size tire problem, but what if you have a car with no Traction control?
    2003 Marauder... the gentleman's hot rod.
    You know what I like best about most people? Their dogs.
  15. #30
    Winnipeg,Mb.
    Quote Originally Posted by daddyusmaximus View Post
    You can run the same size tire front/rear.
    -Mike
    #6018 of 11,052
    Trilogy #196 - Self-installed
    Stuff done to it. See here.
  1. Traction control min/max
    Last Post: 04-10-2011, 07:54 PM
  2. Traction Control Disable...
    By High-C in forum Shop Talk
    Last Post: 03-25-2007, 01:39 PM
  3. Automatic traction control disable and enable
    By juno in forum Community Discussion
    Last Post: 03-17-2006, 11:04 AM
  4. traction control
    By Bruce Phelps in forum Community Discussion
    Last Post: 07-31-2003, 08:09 PM
  5. Replies: 9
    Last Post: 07-19-2002, 01:03 PM
