Results 1 to 11 of 11
Thread: Head Lights
    Middletown, De.
    Wink Head Lights
    Guys:
    Found a little know/documented thing about the headlights. I stopped for gas the other morning and didn't want the lights on while I was pumping. Left the car run as it was about 20 deg. and wind chill about 5.
    So, I turned the lights off from the far left, automatic position. The lights failed to turn off. I found the lights would stay on until I turned the ignition off. Once the ignition was cycled, the light operation was normal. So, if your stopped at night, with auto lamps on, and turn them off manually, don't be suprised if they stay on till you turn the ignition off.
    Bob, USNavy Retired
    Oct 2002
    North Texas
    If you had turned it one notch further to the manual parking light setting, and THEN turned it back to off, they'd have gone off.
    Now having said that, does anybody know a way to adjust the sensitivity of the headlight sensor so the headlights don't come everytime a cloud passes over?!
    Dean P. ~ Racerx88
    2004 Mercury Marauder 300A
    Silver Birch/Charcoal
    Dig Around in My Garage
    Middletown, De.
    **If you had turned it one notch further to the manual parking light setting, and THEN turned it back to off, they'd have gone off**
    Racer, that's true also, but never got that far. I didn't expect the lights to stay on as they did. It was just an observation as I'd not experienced that before on my old '92 CVLXHPP when I had it. The '02 CVLXSport I traded for the MM didn't have the auto on lamp feature.
    Bob, USNavy Retired
    Jun 2002
    Chichester, NH
    Lightbulb WIPERS ON....LIGHTS TOO
    Remember that if your wipers are on or on delay your headlights will stay on. When you have them on the slowest delay you tend to forget and wonder why you've lost control of your lights.
    Mike Eaton
    A politician is Someone who promises someone another person's money.
    Middletown, De.
    Re: WIPERS ON....LIGHTS TOO
    I knew that! Didn't know the other combination concerning the lights when they are active from the auto on finction, then turing them to off! Learning more each day!
    Bob, USNavy Retired
    KSMM03 Guest
    Bob,
    Something you might want to watch out for. I know its a pain, but might want to shut the car off when fueling, otherwise you may get the "check engine light" coming on. Apparently this happens when fueling the car running. It happens with other Fords and Lincolns. The only way to shut it off is take it to the dealer.
    Middletown, De.
    Originally posted by KSMM03
    Bob,
    Chris. you can clear the light by disconnecting the battery for about 15-30 minutes, or if you know womeone with a code reader, you can clear it that way. Seems to me, that this item should clear itself once the cap is reinstalled. My daughters GenMotors car will clear itself.
    Bob, USNavy Retired
    Chicago
    you may also want to shut the car off while fueling because your car may EXPLODE! [at least that's what my wife tells me]
    slowpoke
    St. Louis, MO
    It's true, static electricty. Boom boom, and your MM will be up in flames!
    San Diego California
    The check light comes on 'cause the gas cap is off, but it WILL reset itself(probably not right away)
    "From the forest itself comes the handle for the axe"
    He's here! Carson James Mo--our 1st
    Born 6/02/2005
    Member Windy City Marauders
    1988 Mustang LX notch
    5.0 5 speed
    Engine by Total Performance
    GONE rear ended by a douchbag on his phone
    1990 Mustang LX Notch bought from the original owner
    2006 Dodge Magnum R/T (hers)
    (\__/)
    (='.'=) This is Bunny. Copy and paste Bunny
    (")_(")* into your signature to help her gain world domination.
    Charlotte, N.C.
    Whenever refueling your car==once out -stay out--do not re-enter car---reason-- Most static electricity( spark produced from us rubbing against seating against our clothing) occurs while exiting the vehicle--thus--Static electricity can spark from re-exiting the car while fuel vapors (Not fumes) are in the air--if spark hits vapors they( vapors) will iginite back to it's source--the gasoine--thus B O O M!!!===flash back---everthing g o n e ! Poof!! SO get out to re-fuel--stay out with the re-fueling process until completed and nozzle returned to it's halter--
    Please! This has been an unpaid ad for your safety----MM man
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
