Results 1 to 14 of 14
Thread: PCV Coolant Hose?
    Mar 2011
    st louis by way of boston
    PCV Coolant Hose?
    I pulled the PCV coolant hose and fluid came SHOOTING out everwhere.
    My question(s) is this; Why? Is it bad? Is it just water? Do I need to replace fluid somewhere? Do I just let it drain into an empty container? Is this normal?
    Lotsa questions today LOL. If I didn't have this resource, who knows how much $$$ I wouldv'e wasted at a mechanic.
    ┼∞█The Black Bomber█∞┼
    Aftermarket Sun Roof, Spoiler and Heated Seats, BC4E Dead Pedal
    PERFORMANCE - ADCO Front and Rear Sway Bars, K&N FIPK Air Intake,
    XCal2 Tuned by DR
    LIGHTS - Self-built HID projectors, True 3000K Osram Foglights
    SOUND SYSTEM - Infinity Reference Speakers All Around, Infinity Reference 4 Channel 465W AMP, 2 10" Audiobahn Subs in Enclosed/ported box
    APPEARANCE - Tints w/Windshield Eyelid, SS Inserts, S55 Tail Light Treatment, Full Interior LED Upgrade w/Guages and Cluster, CMS Gods Head Conversion, Custom Floor Mats From CarMotorsports, satin pedals, self-built black and silver pinstriped interior trim and accents
    CURRENT PROJECTS - Doing what Ford should have done and gutting the interior...Stay tuned. It's a rather large project.
    Quote Originally Posted by bolsen View Post
    PCV vacuum hose?
    The one that goes tot he PCV valve on the right side cam cover?
    Mar 2011
    The hose on the right. I mean fluid came out with some pressure.
    XCal2 Tuned by DR
    It's normal. The PCV system in the 4V motor is "heated" by the cooling system to prevent the moisture present in crankcase gasses from freezing in cold weather.
    Yes, you'll need to replace the amount of coolant you lost.
    Mar 2011
    Anti Freeze? It smelled like nothing and was clear so I assumed it was water from somewhere.
    Also I panicked and put the hose back on right away. When I take it off again, should I just let it drain into a container? How much will come out?
    XCal2 Tuned by DR
    Feb 2011
    Hawaii
    With that said....you gotta also burp the system. And can be a PIA.
    Mar 2011
    Or can I just pinch the hose and put the tip into the coolant reservoir?
    XCal2 Tuned by DR
    Mar 2011
    Quote Originally Posted by screamn View Post
    Which system? The coolant system?
    XCal2 Tuned by DR
    Feb 2011
    Hawaii
    Yes sir if you lost coolant. This will get all the air out of the system.
    Mar 2011
    Just pull the cap off the reservoir and turn the car on until it "burps" right?
    XCal2 Tuned by DR
    Feb 2011
    Hawaii
    Check this out:
    http://reischeperformance.com/refill.html
    Posted by rauder775
    There shouldn't be plain water anywhere in your engine.
    No. There is a specific procedure needed to ensure all the air is removed. Read the link screamn posted.
    Mar 2011
    Damn...All I wanted to do was take off the manifold and clean the oil out of it. Now I just created an all day project with burping involved. Any other tips for removing the Upper IM? I want to clean out the oil before I install my catch.
    XCal2 Tuned by DR
  1. what hose is this?
    By slickster in forum Shop Talk
    Last Post: 09-26-2011, 02:13 AM
  2. SS Hose Kits
    By Todd TCE in forum TCE Performance
    Last Post: 12-20-2010, 07:09 PM
  3. rad hose options?
    By GetMeMyStogie in forum Shop Talk
    Last Post: 03-13-2010, 12:54 PM
  4. radiator hose's
    By mark751 in forum Shop Talk
    Last Post: 10-25-2007, 07:17 PM
  5. FP Hose Clamps??
    Last Post: 01-22-2007, 06:58 AM
