My water pump is good have a new thermostat and the temp hand stills go up. Now i dont have know thermostat at all now i delete it car runs fine just stay cold all the time. Can anybody help me out cause i wanna put a thermostat back n
V7 jt-b vortech s/c
Either a bad thermostat, (put it in some boiling water and see if it opens) or your not getting all the air out of the system. Refer to how to "burp" the system. Might be a Sticky or there are many threads on it. Best bet is to Google burping a Mercury Marauder as the search function is difficult to use.
Make sure it's not in backwards alot of people do this. Also search burp system.
Adopted 3/31/11. Sold
03 300a black #1199
TERMINATOR SWAP
430rwhp. Done by mo's
Even though it is brand new there is a chance it could be defective and make sure it is for a Mercury Marauder! Our T-stats are specific.
+1 on what Mr. Man said!
If you don't have a motor craft t'stat I have one for you depending where your at
03 300a black #1199
TERMINATOR SWAP
Even brand new thermostats can be bad.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
1. New thermostat is in backwards
2. Burp cooling system
3. Bad thermostat
NEW stands for Never Even Worked way too frequently nowadays. Drop it in a pan of water stick in a thermometer and see what it does. Also do not rule out a malfunctioning sender or gauge. So before you say that the car is running hot you should either check the temp it is running at with an infrared thermometer pointed at the water tube right before where the hose clamps on or by using a scan tool you can look at live date from the temp sensor.
Is your radiator fan working?
Member #462
2004 DTR II
2005 H-D E Glide Classic
2009 Super Glide Custom
