Originally Posted by
na svt
There's no benefit to degreeing the stock cams. There's also no benefit to replacng the timing chains if the current ones are serviceable. Keep the new stuff till they're needed.
Don't cam chains stretch with mileage? Obviously there is no problem with them breaking, but cam timing would gradually retard with a stretched chain. I can't imagine why you wouldn't replace them if you're in there anyway.
Any idea what the lifespan of this hardware is? I guess there is "broken", where the guides/tensioners are so worn they make noise and beat things up, and then there is a judicious replacement interval where you're avoiding running them through the last sloppy 20% of their service life.
Lifespeed
