Is there one or is it called something else ,where is it located?First my heated seat last night now the mm wont start,it did this a few weeks ago and if i jiggled the shifter it started not today.
Yes there is a neutral safety switch and I believe it is on the left side of the transmission tunnel under the driver seat. Do yourself a favor and go to 1000shopmanuals.com and purchase the official service manual for the MM. I paid $15 for the manual and it is 2939 pages long!
It has all of the wiring diagrams, how to's and symptom charts in it.
when you do fix yours can you PLEASEEE let me know and how to fix it...mine has been doing this for 6 months i will shake the shifter and make saure its in park and it will start right up....
its weird and when im doing it if it dont start all that happens is my dorrs will lock and uplock its weird.....
i have been told many times beofre its most likly the trans safety switch...car dosent think it's in park so will not start
03 MERC MARAUDER 300A BLACK/CHARCOAL
BORN 6/19/2002
#1576 OF A BUILD OF 7838
MODS:
Motor Rebuid: 7/22/11, Transmission Rebuild: 11/24/10, SCT DR 93 octane tune , K&N CAI, BC4E Dead Pedal, FBM LCM & EATC Fix, Marty-O Fender Badges , "POWERED BY FORD" Coil Covers, Optima Red Top Battery, SS Inserts, Personilized Tags, Factory Spolier , CarMotorSports Badges , 2.5 Crowl Fiberglass Hood , 6k HID Head/ 6K HID Fog Lights , Reinhart Proguard , G2 RED painted calibers , Gorilla Wheel Lock System , FBM "MARUADER" Pedals/ Sills.....
AUDIO SYSTEM:Pioneer 7' Touchscreen DVD Headunit , 2 12' Kicker L7's, Kicker 1500.1 Amp , Kicker 350.4 Amp , Kicker Ported Sub Box, "Big 3" Upgrade , 0 Guage Stinger Wires All Around , Rocksford Fosgate 10 Farad Capacitor , Kinetiks HC2000 Audio Battery , 250 Amp DB Alternator , Dynamat All Around , Rocksford 6x8 Doors, Kicker 6x9 Deck Amplified , Kicker 6x9 in Trunk Amplified ,Rocksford 1' Tweeters Custom Mounted "A" Pillars...
It's the switch on the left side of the trans held on by two small bolts. You are looking for the range selector switch.
Sent from my iPhone 4s using Tapatalk
Thanks ,now that i know what Ford calls it i will order one tomorrow.
when someone fix theres can they sdn me amesage please and explain how to install and were to get bec my car is gettiong bad one a week it does this now and i just shake the shifter and it starts right up
BORN 6/19/2002
MODS:
Range selctor switch 86.00 from ford installing tomorrow
if you have remote start(after market) check the power wire.that was my fix when i had similar problem
better to do a burn-out than fade away
My fault I gave you the wrong link. This is the right one.
http://www.1000repairmanuals.com/cars&mercury-76&112
Installed today piece of cake two bolt,one electric plug and disconect and reconect linkage ,15 mins ,works great.
