Results 1 to 15 of 16
Thread: Driver side fog light keeps burning out?
    Oct 2012
    Gales Ferry, CT
    As the title says, the drivers' side fog lamp bulb keeps burning out. This is now the third time in as many weeks. I've gone so far as to even wear clean latex gloves while installing the bulbs, to no avail. I think that would eliminate the oil on the hands causing it to blow. I think it may be a short somewhere but I have no idea where to start looking. These bulbs are too expensive to keep having to replace like this.
    -Bill
    2003 300A #5377 130,XXX Miles
    Drilled and slotted rotors from Ebay
    JLT
    Stainless Works Long Tube Headers and 3" catback.
    Mo's Tune
    Quote Originally Posted by License2Bil View Post
    -Bill
    Make sure the seal around the base of the bulb socket is intact and not damaged. The socket should lock into the housing, about a 1/4 turn. You should not handle the halogen bulb as the oils from your fingers will cause the bulb to burn out. Wipe off the bulb with some rubbing alcohol and let it dry before inserting into the housing.
    BTW... I have some spare bulbs and sockets if needed.
    Oct 2012
    Gales Ferry, CT
    The socket does lock into the housing. I'm wearing gloves to prevent any oils from my hands contaminating the bulbs. Even then, I don't handle the bulb part of the assembly. I just do it as a precaution and have never had an issue before. When I get back from Florida, I'll shoot you a PM about the bulbs.
    Side note- I read in one thread that you can remove the shroud and make the fogs brighter or something to that effect. I am confused as to which part actually needs to be removed.
    JLT
    Mo's Tune
    If you separate the lens from the housing, there is a deflector the can be removed. Just move it from side to side and pull it out. Don't scratch the shiny surface.
    What kind of H1 bulbs are you using?
    The driver side is usually the most common to go out as it's open to the wheel well area unlike the passenger side which has a full wheel well splash shield in it.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Oct 2012
    Gales Ferry, CT
    I am using Sylvania Silverstars at the moment.
    JLT
    Mo's Tune
    I've used them twice before, both bulbs lasted maybe 100 hrs of use.
    A wise idea would be to go with an HID kit for the foglights, will give you more light output, look better and last a whole lot longer. Fastblackmerc can hook you up with that.
    300B
    Exhaust by Greg
    Once you go HIDs, you'll never go back!
    Oct 2012
    Gales Ferry, CT
    That's what I'm afraid of. I need to nail down a new job first since I lost mine at the beginning of February
    JLT
    Mo's Tune
    Smoke Cloud
    Wink
    That's what she said!
    The KING of BLING!
    BOOST GETS YOU IMPERSONATED!
    Smyrna,Ga
    and u wont have to worry about them burning out....HID'S FTW!!!!
    VORTECH A2A supercharger ,accufab 60mm throttle body,all fluids royal purple,cobra headers and exhaust by todd at Grands,410 gears rebuilt rearend(eaton), 3600 high stall converter,rebuilt transmission by Team Ford of marietta rear girdle,powerslot cryo disc, and stainless steel lines from dennis and tuned by aric at INJECTED INGINEERING
    Oct 2012
    Gales Ferry, CT
    I had forgotten about this thread. I solved the problem. The bulb itself was not burned out. It was a build up of corrosion inside the little 90* connector piece. I sanded down the contacts and put some dielectric grease in. Lights turned on.
    JLT
    Mo's Tune
    Feb 2012
    harrison twp,mi
    Good to see you found the problem
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    May 2011
    Schenectady, NY
    Fbm how much are the fog light hid kits?
    300A Black
    Quote Originally Posted by camelgrundle View Post
    Here is a link to the price in my forum.
    http://www.mercurymarauder.net/forum...ad.php?t=74670
  1. For Sale Driver side taillight
    By Mebot in forum Marauder-specific Parts for Sale
    Last Post: 12-27-2012, 02:03 PM
  2. Wanted To Buy need driver side head light
    By STEPS in forum Marauder Parts/Misc. Wanted
    Last Post: 10-18-2012, 12:38 PM
  3. Wanted To Buy Driver side front marker light and harness
    By FormulaMarauder in forum Marauder Parts/Misc. Wanted
    Last Post: 05-15-2011, 08:49 AM
  4. Wanted To Buy Pass side fog light assembly
    By CobraSVT657 in forum Marauder Parts/Misc. Wanted
    Last Post: 11-18-2010, 12:25 PM
  5. Driver side TAIL LIGHT needed.
    By my_rodder in forum Other Parts/Misc. Wanted
    Last Post: 08-07-2007, 05:19 AM
