Results 1 to 15 of 29
Thread: FRONT wheels and tires.
    Manalapan, New Jersey
    I always see plenty of talk about what tires to use out back for better traction and better performance in the rain, etc. What about front tires? I'm looking to run an 18x9.5 up front with wider tires to improve grip. Does anyone have any suggestions for tires to fit an 18x9.5? And does anyone have any pointers on what wheel offset to run up front with a wider wheel? I saw an 18x11 wheel covered but I'm not looking for that wide of a wheel heh. Thanks in advance guys.
    Oh yeah, I'm driving a 2003 Crown Victoria p71 and I'll be running the tce 14" front brake kit.
    Feb 2012
    harrison twp,mi
    I think Motown is running wide fronts.
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Nov 2003
    Horntown, VA
    I run 255/45-18 on the front w/stock MM rims - 8" wide w/no rubs at full lock rt/lft.
    Plate - "EVILMERC"
    Oct 2010
    I run 20x10s all the way around, it all depends on what look your after, staggered with a rake, or same size tires all way around?
    When i ran oem 18s i ran widened 18x10s up front and 18x11s on the rear
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jul 2009
    CAMer
    Fronts i have 9.5 255/45 (should go wider tire) with 40 offset no problems whatsoever.
    392 Challenger YELLOW JACKET
    12.28@114 stock
    I'm looking to run a wider tire up front for better grip around the turns and better bite for braking. I'll probably be running an 18x11 or so out back to put the power to the ground and I have a set of steelies that I'll throw drag radials on if I decide to hit the drag strip. Could I run a 255/45-18 on a 9.5" wide rim? It looks like the approved rim width for that size tire is anywhere from 8-10". Would that look stretched on the wheel? I'm not after the stretched look.
    Krytin: What tire are you running and how do you like it?
    Nov 2003
    Horntown, VA
    I am just getting done w/Cooper Zeon Sport RS 255/45 - 18 on all 4 corners.
    3 years of daily driving & over 35k miles. Longest lasting tires since I had the car from new! Still corners very well and down to the wear bars on 3 out of 4 (#4 is about hit). Breakaway traction on the rear tires is a little less than when new but not a problem. Very happy w/these and may replace w/Cooper again - depends on what I find for price. I have also run Nitto brand in the past w/good results.
    Always get the 103W load range when getting tires - a must for these cars!!
    Plate - "EVILMERC"
    Jul 2009
    CAMer
    The tire will look stretched that's why I said should go with wider tire in post #5.
    12.28@114 stock
    275/40/18? Or is that too short of a tire? I'm looking at a 265/50/18 and a 275/40/18 on nitto's nt555 line for the front. Is this even a good tire to run up front for throwing the car around the twisties?
    Dec 2010
    In between the where and at
    I'm watching this closely. I am interested in running a 275-45/19 all the way around on my crown vic. The stock overall diameter is 27.2" while the larger tire I am looking at is 27.7" I'm not sure if the extra width along with the extra diameter will fit the front without rubbing.
    Oct 2010
    Quote Originally Posted by 05crownsport View Post
    Shouldnt be a problem unless your car is lowered, i run a 315/35 20 on the front, which is about 28.5" tall and 12.5" wide with no rubbing at all wheel is a 20x10 on a =40mm +offset which perfect for these cars.
    On your wheel and tire choice i would go 18" or 20" as odd size wheels and tires cost a bit more, and the selection isnt all that great.
    ITS ALIVE !!!!!!!!
    Jul 2009
    CAMer
    Quote Originally Posted by MOTOWN MARAUDER View Post
    Great to know that that wide ass tire will fit fine. Opens up a new can of worms for with tire selections now.
    12.28@114 stock
    Dec 2010
    Sounds good! It is lowered by about one and a quarter inch. I'll have to test fit to assure clearance. I already have the wheels...19" mustang wheels from the later models with brembo brakes.
    Nov 2003
    Horntown, VA
    Right front fender liner & the wire harness that runs between it and the fender may be a problem if you are lowered. I cracked the liner & wore a hole in it with the outside shoulder of the tire and gave the harness a nasty rub!
    When I replaced the liner I relocated the harness to the top of the liner and cut away the molded box on the liner that used to shield the harness - just where the tire would hit/rub. Been good ever since!
    Plate - "EVILMERC"
    Dec 2010
    Quote Originally Posted by Krytin View Post
    That's good heads up information!
  1. Matched Tires Front & Rear for Factory Wheels
    By tomt41 in forum Tires & Wheels
    Last Post: 05-21-2010, 05:28 PM
  2. Can You Put R Front tires on the rear wheels?
    By tomd in forum Tires & Wheels
    Last Post: 05-14-2009, 05:56 AM
  3. wheels n tires
    By Jake Steel in forum Tires & Wheels
    Last Post: 10-03-2008, 06:16 AM
  4. Wheels and tires
    By Ed Tarras in forum Tires & Wheels
    Last Post: 11-21-2006, 09:27 PM
  5. wheels tires
    By LightningVic in forum Community Discussion
    Last Post: 01-23-2003, 09:52 AM
