Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: Head/cams/intake swap vs Supercharger
    Mar 2013
    Southwest Florida
    Did a search on this, but didn't seem to come up with much. Has anyone done only some old school work to their motors like ported heads, different cams and maybe a ported or other type of intake vs supercharger?
    I'm going to go on a limb and figure that there is not alot of this going on because of the huge amount of torque required to move one of these cars so the SC is a better choice. But still, just wondering...
    Census here is to go with the supercharger like an Eaton swap. Will cost less than beefing up the motor.
    I myself am building a bored 5.1 forged motor and staying NA instead of going with an SC only because my motor has close to 200k miles on it. No point of doing an SC when something break and then be SOL.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Mar 2013
    Southwest Florida
    What kind of heads/cam/intake are you going to use?
    Feb 2012
    harrison twp,mi
    sounds like a very smart plan
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Dec 2005
    Layton, UT
    Blower will yield more HP per dollar for sure. Mod motor work isn't cheap.
    Matt H.
    (sold)2004' SB, 268rwhp/295tq
    2017 F-150, 5.0
    2013 SHO DIB Performance Pack
    Quote Originally Posted by Vortech347 View Post
    +1
    Eaton swap will cost you roughly $4,000 - $4,500, will yield 420 - 430 rwhp.
    A built N/A mod motor (cammed big block stoker) might net you 400 HP on the high end, but it'll cost you $10k plus to get there.
    If your stock 4.6 V8 is healthy.....no question....go with the S/C set-up.
    Ask me how I know.....
    Quote Originally Posted by sflrainmaker01 View Post
    04 Cobra heads freshened/cleaned up with new seals, springs, cam gears, 98 cobra intake cam degreed, valves clearanceed, MM lower intake ported, and 39 lb injectors. Have a FRPP Boss big bore block which will be bored out to 5.1 and going to have close to a 11.0 compression ratio with forged crank, rods and pistons.
    300B
    Exhaust by Greg
    Mar 2013
    Southwest Florida
    That sounds like a sweet combo!
    I don't hear about too many people porting the intake. I know on my 5.0 Foxbody, porting that lower intake made a HUGE difference.
    There is some power to gain from the intake being ported but it's more or less a mod to make other mods benefit more. Such as the intake spacer, it doesn't do much on a stock motor but if you add an intake, larger TB (which I going with a bbk twin 62mm unit) and headers it makes the mod a lot more effective and efficient.
    300B
    Exhaust by Greg
    Jul 2009
    NH
    I ran ported heads, 98 Cobra cams and both a NAZ PSRI and my own ported long runner. Go sc, you'll end up there anyway if you're even asking...
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    Oct 2010
    I would stay away from the BBK throttle bodys, Injected Engineering has a ton of them off of customers cars that leaked thru the butterfly shaft and caused all kinds of idle problems on the dyno!
    I would go Accufab, or Draggon
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Dec 2005
    Layton, UT
    Quote Originally Posted by MOTOWN MARAUDER View Post
    Accufab FTW! Pricey but worth it. Got one on our 03' Cobra.
    Matt H.
    2017 F-150, 5.0
    Sep 2008
    San Antonio, Tx
    The Ford DOHC motor from this era can breathe pretty OK from the factory, at least enough so that porting bits won't get you stupendous goals due to the cam simply not being hot enough. I believe that if you can spec it right, a cam swap would be a huge benefit, but when you are talking about four camshafts and all that supporting valvetrain, that's a lot of money.
    Also, to really make this car scoot, you're going to want to increase your torque across the board, but particularly in the lower RPM range, and without adding cubes, that's gonna be a lot harder to do with internal engine mods than if you just toss a roots blower on it. The 4.6 is just too darn tiny to make a car this big really move, in any of the N/A configurations it was built.
    ‎"Idiocracy" wasn't a comedy, it was a documentary in-the-making...
    Jul 2009
    NH
    Maybe the single blades, not the twin bores. I've had a twin 65mm BBK (Thank you Glassman!) for the entire time I've had my car. Not a prob throughout any of my upgrades.
    Drag racers prayer:
  1. For Sale 98 cobra intake cams
    By breeze in forum Other Parts for Sale
    Last Post: 03-04-2013, 03:54 PM
  2. For Sale 96-98 cobra intake cams
    By na svt in forum Marauder-specific Parts for Sale
    Last Post: 05-02-2012, 10:26 PM
  3. Wanted To Buy cobra intake cams
    By breeze in forum Other Parts/Misc. Wanted
    Last Post: 04-16-2012, 09:55 AM
  4. For Sale 96-98 cobra intake cams
    By na svt in forum Other Parts for Sale
    Last Post: 08-16-2011, 05:36 AM
  5. For Sale 96-98 Cobra intake cams
    Last Post: 06-10-2011, 12:14 PM
