Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Lighted Door Switch Repair - Writeup
  1. #16
    Dec 2007
    Toronto, Ontario, Canada
    Mine just starting doing this intermitantly.
    This writeup will help tremendously!
    Thanks.
    "Barry's" the name;
    Drums and Cars are my game
    "I smash the pedal; air and fuel go in; witchcraft happens; I go fast!"
    "No question is stupid, if you don't know the answer!"
    2004 / Black / 1981 of 3214.
    #184 of 509 in black out of 1214 total in all three colors with the moonroof option.
  2. #17
    May 2008
    detroit
    anyone have a similar repair on the (intermittantly) lighted seat switches?
  3. #18
    Apr 2003
    Kansas City, MO
    Wait the power seat buttons are supposed to be lit?
    Black 2003 300A Marauder Build Date 06-02 100K Miles, Bought used 05/07/11 (SOLD - Uncle)
    HID Morimoto Mini Projector Headlights (built myself), HID Morimoto Matchbox Projector Foglights, Pioneer Z140BH Headunit w/Pioneer 3 way speakers, XM Radio, backup cam, GMRS radio installed, LED backlit gauge cluster, tint, McGard & Gorilla locking lugs (all of them), Cooper RS3A tires, dead pedal, 4.10s, MO's Tune, 3" Fuel Filter.
    Black 2003 300A Marauder KB Supercharger, 120K Miles, still researching build specs.
    Other Owned:
    00 White CVPI (KTA Car)
    2003 Black Chevy Suburban Z71
    2009 White Tahoe PPV
    2019 Blue Ram 1500 Laramie
  4. #19
    Apr 2010
    Western Canada
    Quote Originally Posted by steve fox View Post
    Probably talking about the heated seat switches. Mine were intermittent.
  5. #20
    Feb 2011
    North Jersey
    Well done. Very instructional and visual
    Thank you for your time.
  6. #21
    wilmoo13 Guest
    Just purchased my first MM, a 2003 with 77K, one owner and mostly all original. K&N went onto it last night, trying to decide on exhaust system, recommendations welcome. If there is a better place to get started than here, please let me know. I stumbled on this post because I have a switch panel problem which appears to be common. It is loose, probably missing the famous tab. If I get the panel back in place and close the door all is good.
    One other problem is the remote mirror control. I'm going to assume that it is just the control button itself. Both mirrors will move in two directions and not in the other two directions.
  7. #22
    Apr 2003
    Kansas City, MO
    As far as the mirror switch you might post a pic so we can tell you if its the correct switch, as other years will fit in and plug in but not move all directions.
    Other Owned:
  8. #23
    wilmoo, the mirror switch can be taken apart and cleaned similarly to the window switches. You can try that, but I did it and it didn't last very long. I ended up buying a new switch from tascaparts.com
    Jan 2005
    Just South of Memphis, TN
    Excellent Directions...
    My window switch lights are out... just driver side widows...
    Did the search and bingo...now I'm all set to do the repair...
    Thanks so much,
    Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
  1. Window switch repair question
    By Slowpoke in forum Community Discussion
    Last Post: 02-20-2013, 02:37 PM
  2. Rant...Garage door repair
    By JAYSILVER04 in forum The Lounge
    Last Post: 12-07-2010, 07:21 AM
  3. Power mirror switch repair
    By RF Overlord in forum Shop Talk
    Last Post: 10-02-2010, 06:56 PM
  4. Blend Door Repair $1,200??
    By beauimpala in forum Shop Talk
    Last Post: 05-11-2008, 10:39 PM
