I just discovered that my R axle seal is leaking. Gears were done about 45 days ago. I had the gear install kit installed with the gears.
How difficult is it to replace the r side axle seal and if anyone has a step by step I could possibly do it.
VMARAUDER -
2004 Dark Toreador Red
Simply called "The Red Car", Build Date 4-20-2004, #2618 of 3214, #849 of 980 in DTR, Stainless Works LT Headers with SW Full Exhaust, Ford Racing 4.10 Gears, Carbon Clutches, Dyno by Modern Muscle, Mo's Speed Shop Tune, 277 rwhp 296.43 torque, Moonroof, Rear Spoiler, K&N CAI, Alpine CDA-117 CD Receiver, PAC SWI-JACK Steering Wheel Control , Rear Spoiler, Viper Alarm, From Sparta Performance...Rear Upper and Lower Control Arms, Watts Link, Stainless Steel Brake lines, Raybestos R300 S Groove Rotors with Advance Tech Ceramic Pads, Pro-Gard
It Ain't What You Got It's The Way You Use It
New DD 2014 F150 Lariat - EcoBoosted
and 2013 Lincoln MKX
1998 Grand Marquis GS 175K Sold at 199k
2001 Lincoln Town Car Gave away at 251k
RIP 2003 Garnd Marquis LS 280k miles
RIP 1990 Lincoln Town Car Cartier 295k miles
This is from the MM Workshop Manual:
12.073 @ 118.43 (Nitto 555)
Drag racers prayer:
Thanks Man, I am going to see what the shop that did the gears say 1st before I go into it.
VMARAUDER -
Yes do it the shop should be responsable for it.
That is the 1st thing in the morning. Sent them an email already and I expect them to do the right thing and if not I will just fix it or have it done.
Do you suppose a couple of burnouts could haave done it? Never have before, popped a few wheel cylinders on drum brakes in the 70's though
VMARAUDER -
No. The axles rotate the same regardless of TQ applied.
Matt H.
(sold)2004' SB, 268rwhp/295tq
2017 F-150, 5.0
2013 SHO DIB Performance Pack
Probably leaking from day 1 then
if the vent tube is plugged will the axle seals leak on one side or both or could it be either left or right
VMARAUDER -
This is easily caused by resting the axle half in/half out. Seen it many times. If it was a reputable shop I'm quite sure they would already know that's a no-no and it may just be a bad seal altogether. Basically it's hard to prove. Easy job regardless, but still sucks.
"Since 2004"
So if that happened they did not use my install kit???
VMARAUDER -
No, I'm sure they would have. But while they were setting up the diff, they may have rested the shafts in the housing after already doing the bearings and seals. Seen plenty of bad seals as well. That's just one of those things you can't really lay blame on. Most shops I know would just replace it to keep in good standing and never question it. They'll probably take care of it.
"Since 2004"
Just decided to check drivers side and its leaking too
Going to crash now before I find out something I don't want to find out
VMARAUDER -
The shop should fix it up no issue for you.
#2941 300A
4.10's, carbon clutches
Marty O Tune
Curless Cure
Widened Wheels
Dead Pedal
Eaton Swapped
Bar tender and maker of:
Christmas in a cup
One Legged Lesbian Kickboxer
Cocka Two
Axle vent tube...black hose is not blocked. The port on the axle, is it a type of pressure relief valve? I stuck a small plastic rod in there and it came to a stop about an inch down.
VMARAUDER -
mine is leakng also on the rear passanger and when i did a burnout only one tire is spining would that cause the problem also
One has nothing to do with the other.
The leak is a bad seal. The "one-wheel peel" is worn clutches in the Trak Loc.
