Results 1 to 15 of 29
Thread: Air Suspension Issue
    Aug 2007
    Du Page County, IL
    Ok, so after my MM sat mostly motionless for a month, it seemed to have developed an issue with the air ride suspension. The rear is a bit low, not really getting lower, but firing up the compressor it doesn't raise up. I suspect maybe the solenoids aren't opening, but I'm afraid to flip the switch to lower the rear end in case I can't reinflate the air bags. (the air ride controller failed some years back, so I performed a bypass mentioned in another thread here to install a switch) Since the compressor is firing up, am I most likely correct in my assessment of the solenoids? I suppose I should probably take a few moments to inspect the fuses just to be safe.
    Has anyone had good experience with replacing the the air bags with springs? I'm seriously considering the conversion.
    "Beast, Jr."
    2003 300 A, 4.10:1 gear, JLT CAI, Marty tune, Nitto 420S and 555 tires, NGK TR55 plugs, J-mod, Skull lock knobs, and a new windshield
    Have you checked the ride height sensor? It can pop off when worn or corroded..it's onthe driver's side attached to the watts link
    ^^^what RubberCity said^^^
    You said "the air ride controller failed some years back, so I performed a bypass mentioned in another thread here to install a switch"...can you elaborate? Are you talking about the module behind the glove box failed? You installed a manual switch of some kind?
    Aug 2007
    Du Page County, IL
    Yes, that module failed. It would only work during warm weather which left me freezing my fingers off trying to manually pump air into the springs in the middle of winter. I found a guide in a post on the site somewhere that gave instructions on how to bypass the module and install a manual switch. That "fix" has been working well for several years now.
    Nov 2012
    Sacramento
    Where is the modulator? Can I raise the rear height a little? Is there a setting somewhere I can adjust?
    The module is behind the glovebox.
    To raise the ride height, adjust the sensor on the Watts link.
    ^^^what FBM said^^^
    I *believe* sliding it toward the centre of the car raises the height. Also be gentle with the bolts on the sensor...they're small and have been known to shear off.
    Aug 2007
    Du Page County, IL
    Ok, so I did a quick test and I can confirm hearing the solenoids open and close. I think maybe the air line is pinched or damaged. Can anyone fill me in on where that line runs so I can inspect it?
    Jun 2012
    Grand Rapids
    Quote Originally Posted by ledzilla View Post
    The compressor is located under your air filter box, the line runs along the driver's side frame rail inside next to the brake lines. I have GIGAN's car in the air right now and just looked at it.
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Aug 2007
    Du Page County, IL
    I'm good on the compressor location, but I wasn't sure about the line. Thank you. Knowing that, I now suspect that when we had to cut the crossmember bolts out with a torch we may have damaged the air line. I'll have to inspect it first chance I get.
    Since it's plastic, that sounds logical.
    Jun 2012
    Grand Rapids
    Yep, the line runs right above the X-member
    #2941 300A
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Christmas in a cup
    Cocka Two
    Aug 2007
    Du Page County, IL
    When I have a few moments to spare I'm going to fire up the compressor using my handy-dandy switch I installed in the glove box, and listen for any leaking air along the chassis. With any luck I can find it in a spot easy to repair. Does anyone have recommendations for repair materials? I know there is the chance that the damage may be in an inaccessible spot and I might have to rig up some flexible hose or something.
    Wisconsin
    Cut out damaged area & splice in repair section.
    If lucky, only small spot damaged & enough slack to splice with air-line quick-union.
    If larger section damaged, 2 quick-unions & a new section of line.
    Back on the road.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Aug 2007
    Du Page County, IL
    I have a sneaky suspicion that the damaged section will be somewhere hard to reach in reference to the cross member, and I'll probably need a pair of connectors and some line. Who sells it?
  1. Air suspension (air up) procedure?
    By HPJim in forum Steering, Suspension & Brakes
    Last Post: 09-04-2010, 06:03 PM
  2. KB Front suspension Issue
    By John F. Russo in forum Steering, Suspension & Brakes
    Last Post: 01-15-2009, 01:54 PM
  3. Air Ride issue
    By Digital Man in forum Shop Talk
    Last Post: 04-21-2008, 07:34 AM
  4. Air suspension issue
    By Go Mifuni in forum Shop Talk
    Last Post: 08-02-2007, 06:35 AM
  5. Got my Marauder back, air suspension issue?
    By Fourth Horseman in forum Shop Talk
    Last Post: 01-05-2004, 09:22 AM
