I have 2 questions. So I found some hood strut prop on ebay. Seems like that's what they are called. Ive seen different hight as well as different ball size.
Does the height matter for the actual prop?
What size is the ball, 10mm or 13mm?
https://www.ebay.com/itm/10MM-Nitro-...00989901fd8bd6
https://www.ebay.com/itm/13mm-Nitrate-Coated-Nitro-Prop-Gas-Spring-Strut-Shock-Ball-Stud-Mount-SAE-5-16/371241585760?epid=11023340917& hash=item566fb90c60:g:vnoAAOSw d4tT0qJC
O3Merc if your read this it's not letting me reply to your pm it saying you exceeding your storage to clear up space bro
I think I might need the hood pins after all I saw it shaking on the front sides when going 75mph
I guess mine got delivered yesterday to work. Unfortunately on the 5th a herniated a disc in my low back and haven't returned to work yet. Still can't lift over 10 lbs
#BSTDMRC #LSSWAPPEDMARAUDER
Instagram -
Cheapthrillb2
lsswappedmarauder
ok guys, so I received my hood on the 17th. Installed it the same day as I had in hand the recommended hood struts from advanced auto. Everything went well and install was a breeze. aligned with out any issues and fitment was great.
I'm trying to post pics but it keeps saying upload failed. Tried both from uploading from computer and adding a direct link.
I do want to say that after a total of 10 days of the hood being installed on the car, the hood is starting to bulge some by the fender area. there is also a small pimple growing where the hood hinge meets the hood.I have pics to post so that you guys can suggest with ideas but my uploads are failing. I need help quick
2019-07-02_07-53-43 by Cheapthrillb2, on Flickr
Got mine set on. Still need to install the aerocatches and hood struts.
Instagram -
Cheapthrillb2
lsswappedmarauder
Can you please give me the extended length of the intrepid hood struts you have on your cowl hood?
I see different length online and just want to make sure I get the correct ones. Happens that my hood is starting to rise towards the middle by the fender. This sucks
Thank You
BOXI 2 Pcs Front Hood Gas Charged... https://www.amazon.com/dp/B019ERCQFQ...p_mob_ap_share
Instagram -
Cheapthrillb2
lsswappedmarauder
There are currently 3 users browsing this thread. (0 members and 3 guests)
